2000 blazer tweeter install
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=20277
Printed Date: May 29, 2024 at 3:54 AM
Topic: 2000 blazer tweeter install
Posted By: LEOAYERS
Subject: 2000 blazer tweeter install
Date Posted: October 18, 2003 at 6:39 PM
I am currently installing a set of Polk audio component systems in my 2000 blazer and I can't figure out a good spot to mount the tweeters. If anyone has sone an install on htis truck can you give some heads up on good place to put them. If you have some pictures that would be great too. Thanks
Posted By: mj239air
Date Posted: October 18, 2003 at 8:21 PM
Don't know what the door panel looks like compared to my 2000 Suburban, but I installed mine in front of the seat heater buttons on the door panels. I have the leather interior and it goes to a kind of a point and installed them there. No pics, but sound wonderful.
Posted By: Alpine Guy
Date Posted: October 18, 2003 at 8:43 PM
the tweeters are supposed to be mounted as close to the woofers as possible, if you mount them to far away then you will have bad sound imaging, that is the biggest mistake people make with component systems. Just find a place about 2 inches from the woofer, cut a hole and mount it, it will look great as long as you don't cut the hole to big.
