12" Solobaric w/ Alpine amp
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=21331
Printed Date: May 28, 2024 at 9:06 PM
Topic: 12" Solobaric w/ Alpine amp
Posted By: bigjerman
Subject: 12" Solobaric w/ Alpine amp
Date Posted: November 11, 2003 at 7:13 PM
Wanna know if u how can u hookup up a 12" solobaric ,its the dual 4 ohm sub, to the alpine mrv-1507 amp to get the most out of it?
------------- 1998 Volvo S70 T5 - It's Swedish isn't that weird?
Posted By: bfog99
Date Posted: November 11, 2003 at 7:51 PM
no. you will need to run it at either 2 ohm or 8 ohm. so that amp will give you between 300-450 Watts RMS depending on the voltage of your car. What version of the solobaric do you have? the L5, L7? Depending on the model, you will want between 600 and 750 Watts RMS. If you have the L5, needing 600 WRMS, I would look at the JBL BP600.1. If you have the L7, needing 750 WRMS, I would look at the Rockford Fosgate801S, Orion 8002, or others like that. Most of what I looked into real quick was pretty pricey so I will let you look into it. Let us know if you have any other questions.
