Different amp wiring, 95 civic
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=22854
Printed Date: June 15, 2024 at 9:29 PM
Topic: Different amp wiring, 95 civic
Posted By: iairj84
Subject: Different amp wiring, 95 civic
Date Posted: December 14, 2003 at 8:47 PM
I am looking to purchase a 95 civic, yes its a civic, i know how generic, but its a good buy. Well anyways, the guy who had it before had an amplifier, and instead of taking the amp power wire directly from the battery, (which I was always taught to do) the guy took it directly from the fuse box, now on honda's they have a large area on the fuse box where you can put it, but I dont know if this is a good thing to do, I can easily just run the wire back, directly to the battery, but if this way will work then I will leave it. thanks
Posted By: auex
Date Posted: December 14, 2003 at 9:29 PM
If he took the power from the battery input into the fusebox it would be ok (assuming that you are talking about the fuse box under the hood), I would still recommend taking it directly from the battery.
------------- Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Posted By: iairj84
Date Posted: December 15, 2003 at 6:29 PM
It was connected to the battery portion of the fuse box next to the steering column, is this okay?
Posted By: Geeque
Date Posted: December 15, 2003 at 6:50 PM
Absolutely not recommended. Go to battery for power. ------------- Gary Kline
MECP Master Technician
Posted By: MAXST
Date Posted: December 15, 2003 at 7:20 PM
direct from the batt. Im sure it works, i wouldnt trust another persons work in a car unless i see certification. Also, what if you upgrade, the fuse will pop from the load, and im sure the line from the batt to the line is thin. ------------- I need quality equipment, feel free to donate.
