I have always wanted to have a system centered around a windows computer rather than a car audio head unit. I am curious as to whether I would notice an audible difference between the sound quality of music coming from a computer as opposed to a nice head unit. I cannot find output voltage in the specifications for computer audio cards. Will I be able to hear the difference? Also can you hear the difference between deck with 4V preouts and a deck with 8V preouts?
The answer to your question is yes there is an audible difference between a computer and a audio cd player, generally speaking computer outputs are low voltage and high impedance, they are designed to be a computer first and not an audio source. Between brands there is a drastic difference in sound quality and preout voltages. Very very few of the cd payers that claim a 4 volt or 5 volt preout actually make that much clean voltage, they generally have a high output impedance and clipping preouts. One of the few cd players that have actually made what they claimed is Eclipse, they generally have a true 8volt rms non clipping (0db) preout at a low 55ohm impedance, this is part of the reason why an Eclipse is a little more than evey one else. The lower the impedance, generally speaking the better the sq, the tradeoff is immunity to noise, it costs Eclipse more $ to keep the noise out and maintain SQ. A non clipping preout gives you just that, a cd player that can play to full output and not distort the audio signal, again this costs more $ and most companies will not pursue an audio signal to this length. It is well worth your time to listen to a cd player like a Kenwood and then install a 5volt Eclipse in the same vehicle on the same system, your ears will tell you the rest.
I'll second what Rob has posted, but also add that the output quality from a computer depends entirely on the sound card in the computer. Systems with built-in audio or cheap $12 sound cards will sound like hell. But good quality sound cards will exceed CD recording quality easily. I have a PC-based Digidesign Pro Tools digital audio workstation with sound quality that will blow away any head unit I have ever heard. The good quality Sound Blaster card in my laptop connected to the line level AUX inputs on my Nakamichi HU can sound far better than a factory recorded CD. So, it depends!
