deck noise
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=24919
Printed Date: May 28, 2024 at 4:16 PM
Topic: deck noise
Posted By: Dustinsmithone
Subject: deck noise
Date Posted: January 20, 2004 at 1:42 AM
I just installed my deck, and now everytime I change the song it makes sounds that come through my speakers, kind of like feedback, I get like a buzzing, fuzzy sound when Im between songs or when the music isnt playing, how do I fix this problem?
Posted By: sufferrar
Date Posted: January 20, 2004 at 6:39 AM
It sound like it's the motor sound of the cd player ... if you have a good brand deck it should not be so...what brand do you have . check your grounds on the deck. Turn the volume down to 0 and change tracks and tell me if the noise is still there....
------------- "I'm So Loud It Hertz"
Date Posted: January 21, 2004 at 1:48 AM
Its still there, my ground seems to be fine! I know that if your ground doesnt have a very good connection it gets alot of feedback but my ground seems to be fine?
Posted By: DYohn
Date Posted: January 21, 2004 at 8:30 AM
Is the deck grounded to the car's wiring harness using a standard wiring harness adapter? If so, disconnect it and make a new ground connection directly from the deck to the car's chassis and see if that helps.
Posted By: Metra Tech
Date Posted: January 21, 2004 at 9:25 AM
It sounds like you are going through a factory amp. What kind of vehicle do you have and what model/brand radio is it.
