dB estimate
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=25746
Printed Date: May 16, 2024 at 2:42 PM
Topic: dB estimate
Posted By: walty220
Subject: dB estimate
Date Posted: February 02, 2004 at 9:00 PM
ive gotta 12" HE2 Fosgate with a 401s Fosgate amp. Its in a sealed box, pushin 400 watts RMS, any body have any clue what kind of spl that might have, even though its punch series?? just guess at my dB, thanks
Posted By: jpranwez
Date Posted: February 02, 2004 at 9:41 PM
Have it measured. Somebody more experience than I might be able to tell you, but they'll want to know what kind of car and probably some other stuff.
Posted By: walty220
Date Posted: February 02, 2004 at 9:57 PM
1983 cutlass supreme,its in my trunk
Posted By: Teamrf
Date Posted: February 02, 2004 at 10:23 PM
Well it's hard to estimate db's...you have to take in consideration about your voltage...box size...ports or no....trunk size...insulation...it's a lot of things you have to think about before you can estimate dbs it's almost impossible to guess it. Because to go from 100 dbs to 103 dbs you have to double something to get there. So without having it metered you are basically clueless.
------------- ~The Rookie~
Rookie of the year that is...
Don't let the smoke out of your equiptment..it doesn't go back in.
Posted By: Julian59
Date Posted: February 03, 2004 at 1:13 AM
Below 98db for sure. the speakers are not efficient enough. Julian59 ------------- Be Smart Never Assume
Improvise Adapt and Over Come
Installer/Technician 20 years
Posted By: forbidden
Date Posted: February 03, 2004 at 1:04 PM
I would bet that he is above 115 db, maybe even closer to 125db. Most single sub systems are certainly capable of this, but like stated above, have it metered. There are a lot of factors that add to spl levels, teamrf mentioned some above, another is cabin gain, and it will have a lot to do with your reading.
------------- Top Secret, I can tell you but then my wife will kill me.
Posted By: Julian59
Date Posted: February 03, 2004 at 1:56 PM
walty220 Ok here are the specs, no guessing just the facts! The Rockford Fosgate HE2 (RFD3212) it's efficientcy is only 87db@ 1watt / 1meter Power Handling (RMS) is 400 Max is at 800 at 4 ohms. If you max this out at 800 watts you'll only maybe get an increase of 4 db. The numbers don't lie, always do the math before you buy. Sorry if this isn't what you want to hear. Julian59 ------------- Be Smart Never Assume
Date Posted: February 03, 2004 at 2:20 PM
Julian, not to knock you at all but do a little more research into the math involved. If It generally assumed that a doubling of power is a gain of 3db, then we need to check the math. If it is in a ported enclosure, then add 3db as well, add cabin gain, this is pressurizing a small airspace, not a big room. A factory stereo with no sub can play above 100db. I stand firm that the system should play above 115db and probably close to 125db. Please let me know what you think on this if you have or I have any misconceptions. 1 watt = 87db 2watt = 90db 4watt = 93db 8watt = 96db 16watt = 99db 32watt = 102db 64watt = 105db 128watt = 108db 256watt = 111db 512watt = 114db ------------- Top Secret, I can tell you but then my wife will kill me.
Posted By: Julian59
Date Posted: February 03, 2004 at 3:29 PM
Forbidden Thank you for the heads up, but I'm sorry to say that's not right. The speaker in question is rated at 87db @ 1 watt / 1 meter. There is no way this speaker will ever come close to those figures you have. It doesn't matter what type of enclosure this is in. Rule of thumb is in order to gain 3db is to increase the power no lell then 100 watts. You will gain SPL but no more then 3 dbs +- .05. I hav't read the MECP manual in about 10 years. but I do know that's this is in there. Check it out. The key word here is DBs. Thx Julian59 ------------- Be Smart Never Assume
Posted By: jpranwez
Date Posted: February 03, 2004 at 4:34 PM
Exactly what does the efficiency rating mean. I was told it's the sound level that a sub is most efficient but that sounded odd.
Posted By: jeffchilcott
Date Posted: February 03, 2004 at 4:40 PM
i would say it probably measures close to a guy i installed the same stuff in a 90 cougar...about the same size car maybe a little bigger. he measured 121.3 db so maybe that will answer your question.
------------- 2009 0-1000 Trunk WR 154.0DB 2009 1001+ Trunk WR
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
Date Posted: February 03, 2004 at 4:44 PM
This "spec" has a real meaning, it however does not tell you how something will sound or how it will react in a vehicle or enclosure. It is a measurement of how loud the speaker plays as compared to all others. This "spec" is also one that has an agreed upon standard in the industry. In general terms this is what it is. The speaker is mounted in an anechoic chamber (a dead room - no reflections) The speaker is fed pink / white noise (think of a dead channel on a tv) The speaker is fed exactly one watt of power. The speaker has a microphone exactly one meter away from the speaker. The microphone measures how loud that speaker "plays" the test signal and records it in decibels. Thus the speaker is given a "spec" of in this case 87db/1w/1m A speaker that is more efficient, say 92 db will play much louder with the same amount of input power, a speaker that is less efficient, say 82 db will play much quieter with the same amount of input power. ------------- Top Secret, I can tell you but then my wife will kill me.
Posted By: sssssss27
Date Posted: February 03, 2004 at 4:59 PM
I'm going to have to agree with forbidden, while I don't have much hands on experience, I have been reading as much as I can the math side of things. I have always heard in order to increase 3db you need to either double the surface area or double the power. Like the other people are saying though there are a lot of variables.
Posted By: MAXST
Date Posted: February 03, 2004 at 5:44 PM
forbidden is right. The speaker isnt even in any box..its just sitting there. ------------- I need quality equipment, feel free to donate.
Posted By: geepherder
Date Posted: February 03, 2004 at 6:43 PM
Julian59, Rob is correct. The numbers do not lie, as you put it. There is a theoretical 3 dB increase for every time the power is doubled. If you increase the power tenfold, the decibels increase by a factor of 10. That being said, if the woofer in question has a sensitivity rating of 87, and we feed it 100 watts, we should get 107 dB's. Now, if we feed it 400 watts, as in the original post, we'll get (+3+3) 113. Double that to feed max power, and we end up with 116. Mind you, this does not take into consideration cabin gain or the fact the woofer is in an enclosure. I think it's safe to say our friend will be above the 120 dB mark, but there's no telling how much without a meter.
------------- My ex once told me I have a perfect face for radio.
Posted By: jpranwez
Date Posted: February 03, 2004 at 8:27 PM
Thanks for the explanation. I appreciate it.
Date Posted: February 03, 2004 at 8:31 PM
Your welcome.
Date Posted: February 03, 2004 at 9:32 PM
Yeah, Rob that was good, I never knew before how that test was conducted. Jpranwez, do not get efficiency confused with sensitivity. Sensitivity is what Rob posted about, measured in dBs. Efficiency is always expressed as a percentage- how much input power is converted into sound (93% or whatever).
Posted By: Julian59
Date Posted: February 03, 2004 at 10:25 PM
Well it means diffrents things to some and a lot to others. OK lets say you have two 12" subs, if these speakers are rated at 89db @ 1 watt/1meter and you have an amp that rated at 200 watts your basiclly getting 92dbs out of it (not SPL) now if you have a pair of 12" speakers that are rated at 101db @1watt / 1meter with a 2 rated amp at 75 watts each you'll get 101dbs. Yes I know these guys don't agree with me. That's cool. Here's something you will agree with. If you shop around for the most efficent speakers you can find you'll need less power to run your system, that mean less money spent for Amps(power) and less money spent on a huge charging system to run all that raw power that you need for your boom,boom. You can have a system that powered with under 500 watts and sound like 1200 . There is another power test for speakers (using spectrum specifed in EIA Standard SE-013 Section SE3) 30 ft. at .001 watt input = ?? dbs 54dbs 10 ft. at 1 watt input = ?? dbs 93dbs 4 ft. at 200 watts input = ?? dbs 124.5dbs the 2nd dbs is the rating of my sub speakers. My 1963 Chevrolet Impala SS Convertible has tested at 120 dbs and has an SPL of 132 8 speakers. 2 -15s, 2-mid mids, 2 high mids, 2 tweeters. total power of 420 watts ------------- Be Smart Never Assume
Posted By: bberman1
Date Posted: February 04, 2004 at 1:08 AM
forbidden's calcs and DB estimates look good to me.
Posted By: eargasm
Date Posted: February 04, 2004 at 3:20 AM
yeah, Forbidden has it the way i was taught by the experts. 87db (or whatever your particular subs ratings say) is its output with 1watt input. Julian, ya gotta understand, double the power = +3dB. double the input power is 2watts, giving us 90dB. Double again is its expected dB at 4watts input, etc. 1, 2, 4, 8, 16, 32, 64, 128, 256, 512, 1024 watts RMS. ------------- 2001 Ford Fairmont
Alpine DVD, screen,
5.1surround processor,
5ch Class-T amp, TV tuner
and centre channel.
Focal 3way Utopia splits.
VDO navigation. Stinger cap.
Soundstream Exact subs.
Date Posted: February 04, 2004 at 3:12 PM
right on, like i said about 121...have installed the setup in a cougar and it should be close
2007 World Record
Posted By: walty220
Date Posted: February 04, 2004 at 4:35 PM
outta curiosity, at 121 dB.. am i going to be heard from a block away??
Date Posted: February 04, 2004 at 4:50 PM
If the person has bionic hearing, or there is no other noise on the block. It will sound good but not excessively loud.
Date Posted: February 04, 2004 at 7:22 PM
Only if you keep the windows rolled down, and in this cold, I wouldn't think it wise (you might catch a cold) . No but seriously, you do turn it down when you enter a neighborhood or pull up to a light, right? In a properly dampened car with the windows rolled up, even with the system up a good rate, it's noticable outside the vehicle, but not very loud. ------------- My ex once told me I have a perfect face for radio.
Posted By: walty220
Date Posted: February 04, 2004 at 7:45 PM
most small neighborhoods yes..well ATT, i love att. I just want to be heard coming, enough to turn a head,if this set up is incapable... then im sorry for puttin you in the position to break it to me lol, dont feel bad, im learnin, its not gonna hurt my ego.
Posted By: Paradigm
Date Posted: February 05, 2004 at 8:10 AM
Don't let it hurt your ego if they DON'T turn their heads when you go by, either. Some people will just ignore it because they think it's ridiculous to have something that loud (which in a way is true, if you think about it).
------------- VEHICLE: 2002 GMC Sonoma ZR2
Alpine CDA-7940
AudioControl EQT x2
JL Audio 1000/1
JL Audio 10W6 (originals) x3
Kicker ZR120
Kicker ZR460
Polk GXR-6 x4
Polk GXR-4 x2
Posted By: themissinglink
Date Posted: February 05, 2004 at 1:17 PM
I found this in the manual of a JL Audio woofer:
** Efficiency is NOT an accurate indicator of a subwoofer's output capability and should not be used as a comparison to other subwoofers to determine which one is "louder."
Which would imply that SPL is not dependent on the Efficiency of the speaker, but how much power can be put through the speaker.
Date Posted: February 05, 2004 at 3:29 PM
The efficiency rating (a percentage) is not to be confused with the sensitivity rating. ------------- My ex once told me I have a perfect face for radio.
