1992 Lumina sedan confusion
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=30037
Printed Date: May 28, 2024 at 2:53 PM
Topic: 1992 Lumina sedan confusion
Posted By: _Mathias_
Subject: 1992 Lumina sedan confusion
Date Posted: April 09, 2004 at 3:50 AM
Hello, I'm new here and have a question about the stereo wiring in my 1992 Lumina sedan. I looked in the VID on this site and found the color codes for the stereo wiring. My problem is this. It lists a few different wire colors that in my car I have a couple wires all the same color. There's like a couple different wires that are all brown, a couple tan etc.. On the ones that I have several wires the same color, do I hook them all up together? It's confusing the hell out of me. Also there is one brown wire with a white stripe. It isn't listed as to what this wire goes to. Any help would be appreciated here. Thanks, John
Posted By: Ketel22
Date Posted: April 09, 2004 at 7:34 AM
if you havent already cut out the stock harness, i would just reccomend going out and buying the harness that plugs into the stock harness. make life much easier. https://installdr.com/ you may also want to try that site. ------------- Quad L Handyman services
Date Posted: April 09, 2004 at 9:15 AM
The stock harness had already been cut.
Posted By: ccaudio
Date Posted: April 09, 2004 at 7:18 PM
you should have 2 blue wires a light and dark, brown and yellow,a light green and dark green,and a tan the blue wires(light and dark) and grey.all those wires are your speakers wires just like that.if you take a 9 volt battery and put them on the blue wires(light and dark)you can find out the polarity of the speaker.same with the green wires,tan and greywires,and the brown and yellow wire.
Posted By: forbidden
Date Posted: April 09, 2004 at 7:22 PM
aahaa, someone who knows a gm vehicle. Bump for the www.installdr.com site ------------- Top Secret, I can tell you but then my wife will kill me.
Date Posted: April 10, 2004 at 12:25 AM
Okay cool. I used a 9 volt. I figured out which wires go to what speakers and hooked them all up to my stereo. Everything turned on fine and the CD started playing but no sound came through the speakers. I checked the fuses and two had blown. I replaced those and tried to turn the stereo on again and still no sound. I have no clue why I'm not hearing anything from the stereo. It worked fine when I took it out of my Cavalier the day I bought the Lumina so it didn't sit around or anything. Thanks for the help guys and if you know any reason this would be happening it would be greatly appreciated.
