will ported work?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=30652
Printed Date: October 31, 2024 at 6:08 PM
Topic: will ported work?
Posted By: aem7506
Subject: will ported work?
Date Posted: April 19, 2004 at 7:17 AM
I made this box awhile back that i put in a explorer... i had a bandpass bf and it slammed but i wnated something that i built so i made this well when i made it i was lookin for design and didnt calculate volume and now i got 2.2 cu ft inside for 2 12 kicker cvr's it has bass but its real low and not very hard hitten like i wanted i put a buddy of mines ported box in there and it was just what i wanted(box was ported at 29 hz.) so is it possible to add a port to this existing box with only 2.2 cu ft or if not waht should i do
<<98 Mercury Mountaineer>>
"Sound"
Pioneer DEH7300
Pioneer 5/7 (4)
12'Kicker compvr (2)
900 Rockford Fosgate Amp (2)
Posted By: stevdart
Date Posted: April 19, 2004 at 8:14 AM
The CVR should be in a vented box with a minimum 1.75 ft3 as shown an this chart https://www.kicker.com/ShowPage.cfm?filename=compvrsub.html&menu=SUBWOOFERS  You might consider adapting your box for one of them and building another.
Double-check your wiring on the speakers and the wiring to the amp.  Are they DVC 2 ohm or DVC 4 ohm?  When you say the bass is "real low", it sounds like the problem might be related to impedence.
When you have checked that all out, post what exactly you have and how its hooked up.  If you decide to go ported, there are some good calculators available to determine the port size to use.
Posted By: aem7506
Date Posted: April 19, 2004 at 5:55 PM
i have dvc 4ohm subs ran parallel to 2 900 watt rockford fosgates if i were to put the port ina 2.2cu ft3 box what size port would i use
"Sound"
Pioneer DEH7300
Pioneer 5/7 (4)
Posted By: aem7506
Date Posted: April 19, 2004 at 6:17 PM
4ohm dvc runnin parrallel to 2 rockford fosgate 900 watt amps
i wanna put a port in the box but what size for a 2.2 cuft3 box
"Sound"
Pioneer DEH7300
Pioneer 5/7 (4)
Posted By: stevdart
Date Posted: April 19, 2004 at 6:31 PM
Read my post, aem.  You can't use that box ported for those 2 subs.  And what about the wiring?
Posted By: aem7506
Date Posted: April 19, 2004 at 7:37 PM
imeant 2.2 per each chamber sry for nto clarifying that
i need the port size i want some hard hittin clean bass
"Sound"
Pioneer DEH7300
Pioneer 5/7 (4)
Posted By: stevdart
Date Posted: April 19, 2004 at 8:22 PM
Here is your manual  https://www.kicker.com/images/manuals/03CompVRManual.pdf  The cutout dimensions are given here.
