How do I check the alternator’s rating?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=31728
Printed Date: May 06, 2024 at 3:05 AM
Topic: How do I check the alternator’s rating?
Posted By: toyota_4runner
Subject: How do I check the alternator’s rating?
Date Posted: May 06, 2004 at 6:03 PM
In my 1986 4runner, the stock alternator would have 60 amp rating. However, I can see that the previous owner had installed amp(s) in this truck, since there is an amp wire coming into the cabin (he also saved my time!!) I am thinking there is a possibility that he changed the alternator. Is there a way to check , eg by connecting any particular terminals with a multimeter, what is the ampere rating of the alternator?
Also, I need to find if I really need a higher amperage alternator/capacitor.
I did some calculations based on info given in the website below but since I am new I would appreciate if someone can check /correct it
https://www.crutchfieldadvisor.com/S-t3IOSMYH2Ll/learningcenter/car/amplifiers_faq.html
My amps: Kenwood KAC 8401: 60W X 4 RMS = 240 RMS (for speakers)
                   MTX 275 X : 150W X 1 RMS (for the 8 ohm subs bridged at 4ohm )
So total power= 390 W, multiplying by 2 for amp's inefficiency, power = 780W
Dividing by 13.8 V (average voltage) , current = 56.52 A
divinding by 3 to get average current, 18.8 A
Seems like I dont need any high current alternator or capacitor. AM I right? If not what do you suggest if my alternator is a 60 amp alternator?
Date Posted: May 07, 2004 at 9:17 AM
writing just so that it comes on the front page and someone sees it to reply. Thanks!
