Whine in the mid’s and highs
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=32603
Printed Date: May 01, 2026 at 5:35 PM
Topic: Whine in the mid’s and highs
Posted By: One_Evil_Necro
Subject: Whine in the mid’s and highs
Date Posted: May 23, 2004 at 11:57 AM
My roomate and I pretty much finished up his truck last night about 1 AM.  I noticed a small whine in the Mid's/highs, not alternator noise as it happens with the vehicle off,  the noise rises and falls when I adjust the gain.  The Grounds seem to be good, i.e, all going to the same place to a good ground location.  The amps and crossovers are all used, from my old system, could it be possible that the board is bad on the crossover?  Im not sure what else it could really be  =(.  Anyhow, its 2 old PPI art series, and the crossover is an audiocontrol 4 xs.  I'll try different RCA's today, haven't done that yet,, not sure what else it could be though =/
~Jay
Posted By: DYohn
Date Posted: May 23, 2004 at 12:22 PM
Good guess about RCA cables, that could be it.  But more likely, the 4XS puts out a strong (up to 9.5 volt) line level signal, and (depending on which one you have) the old PPI Art series amps cannot handle anything greater than a 4-volt (or in some cases a 2-volt) input.  The ringing you hear is most likely due to a voltage mis-match on the input side, and the only way you can overcome this is to replace the amps.  Try bypassing the 4XS and see if the problem goes away.  If it does, the output voltage is too hot.  Keep the gain turned down completely on the amps for best results in the meantime.
Date Posted: May 23, 2004 at 2:52 PM
Ill give that a try too when I get down to the shop, thanks  =)
~Jay
Date Posted: May 23, 2004 at 2:53 PM
Ill give that a try too when I get down to the shop,I can't recall this noise in the last vehicle it was in, same amps + X-over, the only thing different is the HU, my roomate has the CD 5444, whereas in my old vehicle I had an alpine =/
~Jay
