factory amp turn on how to test
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=32764
Printed Date: May 03, 2026 at 11:26 PM
Topic: factory amp turn on how to test
Posted By: saleengt
Subject: factory amp turn on how to test
Date Posted: May 26, 2004 at 3:14 AM
does anybody know any tricks to test for this wire?
Posted By: raydawg357
Date Posted: May 26, 2004 at 8:21 AM
Check it with a DMM.  It should be throwing 12v
Do it right the first time
Posted By: THECANADIAN
Date Posted: May 26, 2004 at 8:23 AM
There are no tricks.  Do u mean from a deck - use a volt meter   Or on the amplifier - connect +12v and ground then jump constant 12volts to turn on wire.  The amp power indicator should turn on(assuming it has one).  Make sure jumper to turn on is fuled with low amp fuse, and nothing else is connected to the amplifier for safety.  You should probably do this outside your car with a battery charger or other external source of power(Bench test)  Good luck!
Posted By: Velocity Motors
Date Posted: May 26, 2004 at 11:47 AM
Use a light tester or preferrably a DMM for testing this. Turn on your deck and this wire should register 12 volts.
Posted By: forbidden
Date Posted: May 26, 2004 at 2:18 PM
Some of the amplifiers in Ford vehicles also show 5 volts on the turn on line if memory is correct, maybe a newer Rustang for that matter.
Posted By: Sweekster
Date Posted: May 26, 2004 at 2:46 PM
'tis true. Premium sound equipped fords and lincolns use 5 volt remote turn on and power antenna.
Duane...
If you think you're confused, imagine how you feel.   posted_image
