small amp for Alpine SPS-570A 6x8
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=34427
Printed Date: January 31, 2026 at 6:38 AM
Topic: small amp for Alpine SPS-570A 6x8
Posted By: jussam
Subject: small amp for Alpine SPS-570A 6x8
Date Posted: June 23, 2004 at 11:28 AM
i'm looking for a small amp that i can hide in wheel well where my factory amp is ,but enoughh power to push door speakers and how should i wired them.
  these are the speaker
< name=x cM1="3">
Alpine's S-Series speakers feature rugged looks and tough, ultra-rigid cones. The 2-way SPS-570A 5"x7"/6"x8 speaker brings home full bass and accurate midrange with its aluminum-coated polypropylene woofer. The durable rubber surround resists deterioration from heat and humdity, adding years to the life of the speaker.
A titanium-coated PEI dome tweeter produces sharp details across a wide dispersion pattern for excellent imaging. You can swivel the titanium-coated PEI balanced dome tweeter up to 15° to fine tune high-frequency focus. Grilles are not included — factory grilles are appropriate for most installations.
Key Features:
  • aluminum-coated polypropylene woofer
  • rubber surround
  • swiveling titanium-coated PEI balanced dome tweeter
  • frequency response 35-30,000 Hz
  • recommended power range 2-40 watts RMS
  • peak power 200 watts
  • sensitivity 92 dB
  • top-mount depth 2-7/16"
  • 1-year warranty
2-alpine amp mrv-f545 4ch amp
polk audio 6 1/2 frontdoor w/alpine center speaker
polk audio 6 1/2 rear w/8"polk sub
2-12" alpine X type sub
2-alpine mdr-1005 amps
Posted By: customsuburb
Date Posted: June 23, 2004 at 2:08 PM
You might look at the EA2212 2 channel amp from Eclipse. It has a continuous power rating of 50 watts RMS. another choice would be the Alpine MRP-T220. It also has a continuous power rating of 50 watts RMS.
Posted By: jussam
Date Posted: June 23, 2004 at 4:37 PM
thanks
one more question i have a power acoustic amp 1800db connected to two dvc 6ohms wired parallel to 3ohms ea.then wired in series for 6ohms for pair  audiobahn sound Q (alum12q) . the amp cant push the subs, sound horrible rumbles i'm looking for an amp that can give me a (thump )
amp is worthless
Posted By: forbidden
Date Posted: June 23, 2004 at 4:48 PM
Rewire the subs in an all parallel circuit and find yourself a class D mono sub amp that is designed and engineered to operate at 1 ohm mono. There are lots on the market today. Concept, Lightning, JBL, Rockford, Memphis and others all make some great amps for this application.
Posted By: jussam
Date Posted: June 23, 2004 at 4:57 PM
did that i had them wired  in parallel @ 1.5 ohms the amp specs 1ohm stable  quess not
 i know there are alot out there  that say  1 ohm stable but how true ,just look at the one i got sh****t looking for true 1 ohms stable  amps or compatible to push these subs
