2002 Jaguar AMP install
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=34681
Printed Date: April 29, 2026 at 12:59 AM
Topic: 2002 Jaguar AMP install
Posted By: nei00755
Subject: 2002 Jaguar AMP install
Date Posted: June 27, 2004 at 3:35 PM
I would like to install an amp and subs in my 02 Jag S-type. Well it has premium sound and I am keeping the stock head unit but I need to know how to wire out without having pre outs on the deck. I have used speaker wire to RCA converters before, or line converter, or whatever the hell its called, and I tried it on this and it does not work but I figured becasue the speakers are amped already and the number of speakers there are, the impedance level is way down causing it not to function the way it should. Any suggestions?? THanks Jeff
Posted By: raydawg357
Date Posted: June 28, 2004 at 7:53 AM
You will need a Line Out Converter, and try catching the signal after the amp. If that doesn't work, try catching it before the amp.
------------- Do it right the first time
