cavalier rear speaker problems
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=34788
Printed Date: April 26, 2026 at 9:10 AM
Topic: cavalier rear speaker problems
Posted By: cynyde
Subject: cavalier rear speaker problems
Date Posted: June 29, 2004 at 8:55 AM
 This may seem like a dumb question but it has everyone I know confused. I own a 2002 cavalier and recently purchased a set of Audiobahn AS69Q 3way 9x9's. I've tried wireing them. I have four factory wires to run to two wires on the speakers. Most wireing combinations give me audio but horrible static in front a rear speakers. The only combination of wireing that does work gives me only high end and almost if any low end. What can I do to fix this?
Here are the factory wire colors
Left rear : light tan, brown, bark blue, dark green
right rear: dark blue, dark green, light blue with black stripe, light blue
Posted By: raydawg357
Date Posted: June 29, 2004 at 9:14 AM
The wires you should use are tan and brown for the left rear and lt blue and blue for the right rear.  The dark wire are positive on each one.
Do it right the first time
Posted By: cynyde
Date Posted: June 29, 2004 at 9:34 AM
I tried that but I still can't get much low end. There is a little but not much.
Date Posted: June 29, 2004 at 9:41 AM
Sounds as if your factory system is amplified.  The only way you can improve your low end will be to replace your deck and bypass the factory amp to the speakers.
Posted By: cynyde
Date Posted: June 29, 2004 at 9:45 AM
 Thanks for the advice. Looks like I've got some money to spend now.
Posted By: djMINIoompa
Date Posted: June 29, 2004 at 10:42 AM
Raydawg is on the money. Your particular car has a monsoon "upgraded" stereo. Bascially is what he said. You have factory speakers with amps to power them. There is not way around it then just re-wiring it to bypass the amp all together. If you just use two of the four wires, you will still be going through the amp which is creating your problem. I think you ment 6x9's, not 9x9's, but either way, you mite want to return your speakers if you can. If you are looking for low end bass to come from those speakers, its not going to happen. IMO audiobahns component speakers are less that satisfactory and create a very flat sound. Try looking at some other brands if you want to. But either way, you are going to have to bypass the Monsoon amplifiers.
Posted By: cynyde
Date Posted: June 29, 2004 at 2:08 PM
 O.K.  Then I guess my next question is; Where can I find the amplifiers that power them? I don't want to return the speakers cause I'm trying to do an all Audiobahn system.
Posted By: kgerry
Date Posted: June 29, 2004 at 2:33 PM
often it's in the trunk on the drivers side behind the quarter panel trim....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
