1999 Dodge Ram 1500 stereo
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=34831
Printed Date: April 27, 2026 at 7:12 AM
Topic: 1999 Dodge Ram 1500 stereo
Posted By: blue1ight
Subject: 1999 Dodge Ram 1500 stereo
Date Posted: June 30, 2004 at 2:42 AM
My friend has a 1999 Dodge Ram 1500.  His Stereo was stolen on Easter Sunday and he went to go get a new head unit.  He got a sony head unit to replace he factory and installed it.  At first when he played the raido his front speakers worked but not when he played the CD.  Well he sent it to Sony and Sony sent him a new head unit.  Well same thing happend then about a week later he didnt have any front speakers at all.  We swapped the front speakers with the back ones and they worked fine so I know he dosnt have blown speakers.  And yes we tried putting the fade all the way forward.  The Only thing that I saw out of the ordinary was a black wire with a blue strip in the same wire bundle that is with his stero wire bundle that dosnt go to anything we tried putting it to ground but nothing happend on the wire schematic through this site there is no listing for a black wire with a blue stripe.  I guess my question is has any one heard of this and if so how did you fix it to get the front speakers to work.  Thanks for your time and please let me know anything I might have forgotten
Mike
Posted By: stevdart
Date Posted: June 30, 2004 at 6:06 AM
In the process of jacking your friend's deck, the thief probably pulled on the wiring in the truck, and there is some loose or torn connections.  Check your wiring continuity.  You might want to replace the speaker wiring.
Posted By: fuseblower
Date Posted: June 30, 2004 at 7:46 AM
I agree with stevdart.  It sounds like they screwed up his wiring during the jack move.  His best bet is to check the wiring like stev said.  Or you can re-wire the door speakers.
Posted By: kgerry
Date Posted: June 30, 2004 at 8:53 AM
sounds like a remote turn on lead is not connected or is connected to the wrong source...if you hook remote to "power ant" instead of "amp remote" then the speakers will shut off when you put in a CD... i would triple check your wiring.....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Posted By: Velocity Motors
Date Posted: June 30, 2004 at 9:14 AM
I agree with kgerry, the remote turn on wire is in the BLACK connector and the wire is LIGHT GREEN on the end. Make sure that this wire is connected to the REMOTE TURN ON LEAD and not the power antenna lead. If you don't have a designated remote lead, use the RED wire from the Sony deck to power the LIGHT GREEN wire.
Date Posted: June 30, 2004 at 8:31 PM
thanks for the help ill try that out and see what happens ill give you an update when I get one thanks again
Date Posted: July 20, 2004 at 2:28 AM
well all connections are good there is good continuity from the deck to the speakers.  He said he has the infinity sound system in it when they jacked his stock stereo and there is a amp or something that should be in the dash but its missing could this be the problem or were else should we look for problems.  he tried hot wiring the speker directlly to the head unit but still no workie.  Thanks again for all the help.
Mike
Posted By: shott8283
Date Posted: July 20, 2004 at 6:27 PM
i got an 01 Ram and i have an aftermarket head unit....i realized after buying the wrong harness that they make 2 different harness's....1 for a plane-jane stereo and one for the premium   I E infinity system....make sure you have the right harness...if not then the wires will be mismatched and sending wrong signals to the wrong stuff.......
