Fuse questions
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=34954
Printed Date: April 29, 2026 at 7:49 AM
Topic: Fuse questions
Posted By: raptor333
Subject: Fuse questions
Date Posted: July 02, 2004 at 10:47 AM
1. How can you tell what number of amp fuse you should use inbetween you amp and distibution block(it has no fuse)?
2. Do I need a fuse between my power caps and battery?
Posted By: kfr01
Date Posted: July 02, 2004 at 12:25 PM
https://www.bcae1.com/fuses.htm should answer your basic fusing questions.  I don't think it has information re: caps on that page.  I have no experience with caps and can't offer any assistance there. :-)
New Project: 2003 Pathfinder
Posted By: stevdart
Date Posted: July 02, 2004 at 4:13 PM
1.  Fuse this wire same as the amp's  fuse rating that is connected on that wire.
2.  Fuse the power wire less than 18" from the battery positive terminal, (you want it as close to the battery as possible).  The fuse rating is determined by the gauge of power wire from battery to equipment.  1/0 gauge will handle a lot of amperage, so just fuse the wire with a fuse rated at the sum total of all three amps.  This fuse protects the car from fire if the wire gets grounded on the chassis.
So, you will have a fuse in the power wire at the battery, and a fuse on each of the three 4 ga. wires going out of the distro block.
