Amp protection
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=37072
Printed Date: May 21, 2026 at 10:04 PM
Topic: Amp protection
Posted By: Sancho
Subject: Amp protection
Date Posted: August 09, 2004 at 5:38 PM
I have kicker solo baric S15 L5 powered by JBL 600.1 ....when I go with the volume more than a half amp is switching to the protection mode what kind of problem might be???? I only think may be power wire is not enough cause I'm not for sure I think it is 8ga and has fuse only 20A
Posted By: racer427
Date Posted: August 09, 2004 at 6:15 PM
Upgrade to *At Least* 4g power and ground wire and put a 60 amp fuse inline.
------------- Alpine CDA-9833 HU
Diamond Audio M661 Components
MTX Thunder T6.6 Components:rear fill:
Cadence Q400 4 Channel Mains + rears
Thunder 801D Subs
MTX 1004 10's
Dual 4g wire to rear
4g grounds
Posted By: Sancho
Date Posted: August 09, 2004 at 8:31 PM
is this an answer???? change to 4 ga?
Posted By: pimpincavy
Date Posted: August 09, 2004 at 8:35 PM
A bigger ground wire should solve your problem. Most times the protection light comes on its becasue of a bad ground.
Posted By: racer427
Date Posted: August 09, 2004 at 8:37 PM
I Have read that JBL amps are power hungry. Are you running * guage from the battery to the amp? If so, try using 4 guage. I am not saying that this will completley fix your problem but, it is a start.
Thunder 801D Subs
MTX 1004 10's
4g grounds
Posted By: stevdart
Date Posted: August 09, 2004 at 8:52 PM
The amp gain is set wrong. When you turn the head unit up, the amp is going into clipping. Reset the amplifier gain to match the head unit at the highest level that the head can go cleanly. You're not blowing a 20 amp fuse in the power wire, so evidently the amp is not pulling too many amps. And, by the way, what is the fuse rating of that JBL? And why wouldn't you have at least that same fuse rating in the power wire that feeds it? An 8 ga. wire can be fused to up to 60 amps. And let us know what you did as far as making certain the amp ground is good.
------------- Build the box so that it performs well in the worst case scenario and, in return, it will reward you at all times.
Posted By: fuseblower
Date Posted: August 10, 2004 at 7:56 AM
Your amp requires no less than a 60 amp fuse, the reason it is shutting down is because it is running out of power when you crank it. In addition you will want to reset your gains after you upgrade your fuse. The fuse is not blowing because the amps shuts down before the fuse blows due to a lack of power. This amp actually draws 57 amp when fully utilized. And depending on the distance or your amp from your battery and other variables in your car you may look into upgrading your wire to 4 gauge. This amp is very power hungry but reliable. I installed one in a civic and with the car running it drops the voltage down to 10 volts with the car running on heavy bass notes.
