Best amp to push 2 Thunder 8000’s ?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=37117
Printed Date: May 22, 2026 at 11:58 AM
Topic: Best amp to push 2 Thunder 8000’s ?
Posted By: vdubmk4
Subject: Best amp to push 2 Thunder 8000’s ?
Date Posted: August 10, 2004 at 11:57 AM
What is the best amp for the money to push a 10" Thunder 8000 at 300 to 400 watts rms. I have two of the subs but i wanna run mono amps so i can have one on each side, but if there is a good two channel amp for the money then ill consider it.
Fortune: You will continue to take chances, and be glad you did.
Posted By: switch_hitter
Date Posted: August 11, 2004 at 7:13 AM
are the subs DVC?
Posted By: vdubmk4
Date Posted: August 11, 2004 at 8:51 AM
Nope just single
Posted By: padawan
Date Posted: August 11, 2004 at 9:06 AM
Grab that MTX 801D if u want 1 amp, 800Wrms @ 2ohms, if u wire ur subs in parallel that'll give em each 400Wrms...
Posted By: vdubmk4
Date Posted: August 11, 2004 at 11:35 PM
I went ahead and bought two RF old school 360a2's for 45 bucks each from a freind. I think that 360watts rms will push them fine plus i get the dual look i was goin for.
Posted By: MBZ oe
Date Posted: August 15, 2004 at 5:35 PM
Old RF amps are awesome. Nothing like a Punch 150 to remind me of the good old daysposted_image
BOOM, BOOM, BOOM BOOM....
Posted By: lilboi
Date Posted: August 15, 2004 at 8:09 PM
I have the same subs, i'm using the newer 1501 amp. Runs about $400-$500
