Ford Explorer 2002 XLT and amp location?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=3752
Printed Date: June 08, 2024 at 8:52 AM
Topic: Ford Explorer 2002 XLT and amp location?
Posted By: jfkaiser
Subject: Ford Explorer 2002 XLT and amp location?
Date Posted: September 18, 2002 at 7:13 AM
Hi Guys, I have a 2002 Ford Explorer XLT. I did not do any sound upgrade options....so the standard factory cd/cassette combo is what I appear to have. It looks alot like the model dm100i that I found on some websites who sell OEM stereos. I would like to get some better sound in vehicle by starting with one of the following : 1. replace head unit 2. try to intercept existing head unit and route to new 4ch amp. 3. replace speakers with component so tweeter is up near ear-level on door sail panel. I am having trouble finding out and where amp is located (if this vehicle has a separate Ford amplifier that the Ford head unit gets routed thru). If a new head unit is recommended...I would hate to have its signal be passed thru any separate Ford amp (if exists).....so can I bypass. Any help appreciated, Thx, Jon
Posted By: Velocity Motors
Date Posted: September 18, 2002 at 6:15 PM
Hey Jon... I emailed you dierectly about this, what do you think ? ------------- Jeff
Posted By: jfkaiser
Date Posted: September 19, 2002 at 6:58 AM
Thanks for your response Jeff, I really appreciate the help......I followed up with this: Jeff, It sounds like you are saying that Ford always has the amp in back quarter panel? or is it still possible that I have no separate Ford amp at all? I only wonder because my first choice would still be to start with replacing just the head unit......but I am a little conerned that I will be passing my new head unit signal thru into some crappy Ford OEM amp. Since I have just the basic Ford CD/cassette combo..and did not pay for any special Ford sound upgrades......is it possible that I do NOT have any separate Ford amp? Is there any easy way to get into the side panel to check for presence of a Ford amp? Thanks again, Jon
Date Posted: September 21, 2002 at 8:17 AM
What you can do is take the OEM deck out and use a battery ( C or D cell ) and attach a wire on each side of the battery and test the pair of target wires and see if they scratch when you tap the ends of the wires from the battery. This will temporarily give the speakers power and the tapping will make a scratching sound when toy touch the two wires together. If you have a OEM amp then the two target wires for the speakers will not make any sound. If the speakers do make a sound then you have no OEM amp. ------------- Jeff
Posted By: jfkaiser
Date Posted: September 23, 2002 at 8:49 PM
Hi Jeff, Once again you've helped me out.....I didn't see you reply right away or I would have thanked you right away. I will give this a shot and see what happens... Thanks again, Jon
Posted By: Rjahr01
Date Posted: September 29, 2002 at 6:58 PM
instead of emailing replies to individuals why don't you post it so that people like myself can read it, don't mean to sound like a dick, but i would like to know how to remove that back panel on my new explorer
------------- rjahr01
Date Posted: September 30, 2002 at 5:54 PM
This site will help. Just keep in mind that the year of this removal is not the 2002's but the process is the same. https://carstereohelp.com/stereoremovalFordExplorerAmpRemoval.htm------------- Jeff
Posted By: jfkaiser
Date Posted: October 03, 2002 at 9:16 PM
Hi Guys, I finally got a chance to pull out my XLT stock radio and found that I do NOT have any amp. I was able to hook the new pioneer receiver directly up and it sounds GREAT....it makes me not so ready to worry about replacing factory speakers at this time. I may still throw in a sub and leave thedeck powering the front/rear speakers. Anyone know where good place to get thru firewall is on the 2002 explorer?? Thx, JK
Posted By: mcmahonjonathan
Date Posted: October 04, 2002 at 11:41 AM
Hey JK, I had a '94 XLT Explorer with a separate OEM amp. That car was totalled and I just got a '99 XLT Explorer. To my surprise, there was no OEM amp in the new vehicle. I took a small flashlight and looked through the rear right-side seat belt opening in the plastic molding. I saw the wires, but no amp. Apparently Ford prewires all vehicles for an amp to make it easier to do a premium stereo upgrade. As far as the firewall is concerned, there should be a few oversized rubber grommets that existing wires come through (on the driver's side). I drilled a hole through one of the grommets and got a 4 and 8 gauge wire through. There should be plenty of room, but be careful not to slice any existing wires in the process. Good luck.
Posted By: jfkaiser
Date Posted: October 04, 2002 at 3:00 PM
Thanks for the info.....I will check it out and see if I can view any wires thru the seat belt area. That would be nice if I could tap into some pre-existing power. Thx, Jon
