cd player to amp question
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=37578
Printed Date: June 10, 2024 at 7:12 AM
Topic: cd player to amp question
Posted By: bigmikeww
Subject: cd player to amp question
Date Posted: August 17, 2004 at 11:52 AM
i got a pioneer 6300 cd player it has two pre amp outputs. i'm puting a sub amp and a 4 channel mids and highs amp in. my question is should i use the front rca output and put some y-spliters to the 4 channel amp, or should i use the speaker wires input?
Posted By: Francious70
Date Posted: August 17, 2004 at 12:20 PM
Your HU has three pre-amp (RCA) out: Front, Rear, and Sub/Non-Fading. Run the front and rear outs to your mids/highs amp and your Sub/Non-fading to your sub amp. You will get better quality that way.
Paul
Date Posted: August 17, 2004 at 12:23 PM
Oops, sorry. I looked up a DEH-6600. You would want to use the y-splitter. Just make sure you combine front/rear not left/right.
Paul
Posted By: Vidgamer
Date Posted: August 18, 2004 at 10:34 AM
What do you mean combine? I assume he wanted to split the front left into two left signals and the front right into two right signals. Perhaps I misunderstand something....
Mike,
You might want to use the rear outputs, since making a split cuts the power (could increase noise slightly, but probably wouldn't be a noticable difference, but since people pay extra for high output pre-amps, they must be doing it for a reason, eh?).
I've used speaker inputs for the sub, and it works. I went ahead and rewired for RCAs, but it wasn't like a huge improvement -- I think I would be happy enough using the speaker inputs if I had to. Doesn't sound like you'd have to, though.
Posted By: Alpine Guy
Date Posted: August 18, 2004 at 10:41 AM
Doesn't your amp have a pre out?? If it does, , you can send 2 pairs of rca's to your 4 channel like normal ,, then use the pre out on the 4 channel and plug in rca's there for your sub amp.
------------- 2003 Chevy Avalanche,Eclipse CD7000,Morel Elate 5,Adire Extremis,Alpine PDX-4.150, 15" TC-3000, 2 Alpine PDX-1.1000, 470Amp HO Alt.
Posted By: defective
Date Posted: August 18, 2004 at 10:45 AM
ya.... then you could completely void all the frequency adjustments from the deck so you have to manually adjust the amps. -------------
Date Posted: August 18, 2004 at 11:09 AM
thanks for all the input. i'm just afraid with the older pioneer hu that i might get a stronger signal to the amp by using the speaker wires out of the hu and to the 4 channel. and using the rear rca out to the sub amp?
