2001 dodge ram infinity system
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=38056
Printed Date: May 11, 2024 at 8:17 PM
Topic: 2001 dodge ram infinity system
Posted By: BBQ Warrior
Subject: 2001 dodge ram infinity system
Date Posted: August 24, 2004 at 10:54 PM
does anybody know how much power the stock infinity system in a 2001 dodge ram quad cab has? Im looking at a new headunit that puts out 21 watts rms 55wats peak x4 and am wondering if the new head unitisacually more powerfull? Thanks
Posted By: stevdart
Date Posted: August 25, 2004 at 12:00 AM
No, the Infinity system has more power because it has amps on the speakers. The factory system will not be compatible with the aftermarket head unit. Plan on completing the upgrade with new speakers and an amplifier, and bypassing or pulling out the Infinity.
------------- Build the box so that it performs well in the worst case scenario and, in return, it will reward you at all times.
Posted By: forbidden
Date Posted: August 25, 2004 at 11:51 AM
Throw out the Infinity system, it belongs in the trash with the Bose crap. Make sure that the cover to the garbage can is secured properly when you are finished and make sure any of the Bose crap doesn't make a run for it when the cover is lifted. Other than that, stevdart has it nailed for you.
------------- Top Secret, I can tell you but then my wife will kill me.
Posted By: theotherserge
Date Posted: August 26, 2004 at 12:59 AM
I have an 01 Ram and the Infinity system will make a good wheel chock when I pull it out.
Until then, can anyone help me with the wiring? I've identified all the speaker wires and switched + but what are the Y/Bk, O and Purple wires? I expected to see two R wires for power...
