Kenwood KRC-208S
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=41187
Printed Date: June 17, 2024 at 11:47 PM
Topic: Kenwood KRC-208S
Posted By: ealvarez
Subject: Kenwood KRC-208S
Date Posted: October 18, 2004 at 10:33 PM
I installed a kenwood KRC-208S, cassette deck with a 6 disc changer, on my 99 F-150 and everything works great except for the CD Mode. Only my Front Left (FL) and Rear Left (LF) speakers work on CD mode. Tuner and cassette modes work fine, with output to all of my speakers. Does anyone know the possible problem? It is not my "balance", I already checked that.
Posted By: stevdart
Date Posted: October 18, 2004 at 10:54 PM
Most likely an open circuit in the wiring or plugs connecting the deck with the changer. You could test each of the wires for continuity. If all wiring is good, and you've eliminated the plug or plugs as problems, then the problem would have to be internal. The speaker wiring is good, and the deck is receiving proper power...as evidenced by both the tuner and cassette behaving properly.
------------- Build the box so that it performs well in the worst case scenario and, in return, it will reward you at all times.
Posted By: kgerry
Date Posted: October 19, 2004 at 1:21 PM
try wiggling the data connector at the back of the Head unit... they sometimes develop halo cracks around the pins... could also be a problem in the audio section of the changer itself.....
------------- Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Posted By: ealvarez
Date Posted: October 19, 2004 at 1:42 PM
Thank you all for your help. I will try what you have said, check for continuity and wiggle my connectors. Thanks
