RCA Voltage
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=42296
Printed Date: May 19, 2024 at 7:56 PM
Topic: RCA Voltage
Posted By: evanc
Subject: RCA Voltage
Date Posted: November 05, 2004 at 11:25 AM
Lets say you have an 8 volt (Eclipse 8454) signal...and you split it to 2 amps (2 JBL 1200.1), will each of them see 4 volts?
Posted By: DYohn
Date Posted: November 05, 2004 at 11:33 AM
No. "Splitting" places the signal in parallel to two amps so each will see the same voltage. Signal current will be reduced. ------------- Support the12volt.com
Posted By: netboy
Date Posted: November 05, 2004 at 4:29 PM
what is the differnce between signal current and signal voltage?
------------- Memphis MC-1300
2 12" JLw6v2
Diamond audio M3 6x9
Diamond audio M3 5.25 components
Audio control Matrix
Carputer
Posted By: jeffchilcott
Date Posted: November 05, 2004 at 7:19 PM
current=amperage voltage=power volts
------------- 2009 0-1000 Trunk WR 154.0DB 2009 1001+ Trunk WR
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
Posted By: stevdart
Date Posted: November 05, 2004 at 9:10 PM
Ohm's Law states that power is the result of voltage X current. Voltage is the difference of potential between two circuits, and current (amperage) is the result of the voltage. When your deck sends 4 volts to the amp, it is actually a 4 volt difference of potential. Electrically, things will happen when there is voltage. Current will flow through the connecting wire, the current being made up of electrons. Here's a quote from a source I recently read: Basic electrical theory tells us that voltage is a difference in potential. It tells us that a current will flow across this difference in potential. We know that the larger the voltage, the larger the current. We also know the direction of the voltage determines the direction of the current. https://www.seattlerobotics.org/encoder/jun97/basics.html I wonder how the signal is degraded when split? There are some devices, like the Audio Control 6XS, for example, that boost the voltage to about 13 volts so that the signal can be split up to 6 different ways. Now that little remarkable piece of electronics has a lot more to it than that, but it makes me think that the current normally gotten from a 2 volt source should be sufficient. So splitting a 4 volt source into two amps should be no problem. It could be a problem when the voltage is lower than that, or when more devices need a signal input. Then you would use a control device like the 6XS that I mentioned. But don't quote me on this.........sometimes I just have to think out loud.....
Posted By: evanc
Date Posted: November 06, 2004 at 1:18 PM
So, when splitting the signal from the radio to the 2 amps, would it be much better to invest in something similar to the Audio Control 6XS, or would a simple RCA splitter be good enough since the amp only wants a 4 volt input max anyways?
Thanks fellas
Posted By: stevdart
Date Posted: November 06, 2004 at 1:41 PM
All you need is 1. a RCA splitter, or 2. run RCA's from the output of one amp into the next amp input. (most amps have full-range output jacks)
------------- Build the box so that it performs well in the worst case scenario and, in return, it will reward you at all times.
Posted By: evanc
Date Posted: November 06, 2004 at 4:23 PM
Yeah, but will the splitter cause a degredation in sound quality...and if so, will it be noticable?
Posted By: customsuburb
Date Posted: November 06, 2004 at 5:34 PM
You will not notice anything when you split it only once (your deck has 8 volt preouts so nothing should be lost).
