factory stereo problem
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=42465
Printed Date: May 02, 2024 at 7:24 AM
Topic: factory stereo problem
Posted By: supradude
Subject: factory stereo problem
Date Posted: November 07, 2004 at 9:19 PM
I have a 1996 Pontiac Grand Am GT with the factory stereo and speakers in it. Both of the rear speakers stopped working. I was checking to see if they were bad by hooking another speaker to the wiring in the trunk. The speaker that I was using worked on borh sides of the car, so I figured borh of the speakers were bad. Later that day I drove the car and both of the rear speakers were working again. Now, a few days later, both of them have stopped again. I can hook up a speaker to the wiring and they will start back working. Could this be a short in the factory radio's rear signal? Any ideas?
------------- '85 Toy
Posted By: boxmaker85
Date Posted: November 07, 2004 at 9:37 PM
I had the same problem w/ mine. In mine it's not the radio. Mine's just one speaker (back passenger side). It played sometimes and sometimes it didn't. Hooked up an old 6.5 to it. Sounds fine. It plays for a week disconected it now b/c I'm about to put in some infinity 6x9. But I've concluded it must be the speaker. I've checked everything related to it but nothing is wrong. Get new speakers. Guarantee that's the problem.
Posted By: audiopro111
Date Posted: November 07, 2004 at 9:51 PM
make sure the speaker wire is not grounding uot on the deck or basket.
------------- AudioPro111
make sure the speaker wire is not grounding on the deck or basket.
Posted By: stevdart
Date Posted: November 07, 2004 at 10:23 PM
Most likely an intermittent disconnection somewhere along the line. The way those wires are bound and gagged in harnesses, it would be a nightmare to find the fault. This is the time, you know.........put in an aftermarket system. What are they, the original speakers?
------------- Build the box so that it performs well in the worst case scenario and, in return, it will reward you at all times.
Date Posted: November 08, 2004 at 6:45 AM
Yes, everything is original. I would have already upgraded everything, but the car is my wifes, and she wants it like it is. I will probably have to change over everything, but I will try replacing just the rear speakers first, just to see if they are the problem.
Posted By: kgerry
Date Posted: November 08, 2004 at 9:07 AM
i service lots of these situations... the voice coils develop intermittent connections.... replace the speakers
------------- Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
