JBL BP1200.1 Problem
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=42470
Printed Date: May 04, 2024 at 12:20 AM
Topic: JBL BP1200.1 Problem
Posted By: cgalvin29
Subject: JBL BP1200.1 Problem
Date Posted: November 07, 2004 at 9:37 PM
OK well about 1 1/2 years a ago i bought a JBL to run 3 kicker Solo-barics but i ended up aelling the vehicle and taking the system out to sit in my basment till now. I just hooked it up in the last few days because i got a new vehicle that it fits in. and everything went fine and it played great for about 4-5 days then quit. so i just went through it and found the 3X40 amp fuses blown so i replaced them and powered up the amp and immediatly they blew. so i though ok its shorted so i metered both the Bat and Rem terms and the were both 12+ redid my ground and put new fuses in but same thing the red light comes on for about 2-4 seconds then they blow which means excessive voltage on the bat term but ive metered it and its good and the 80 amp fuse at the bat is still good which to me means it hasnt shorted out ive shcked everything even lowered the input voltage thinking that may have been a problem but i dont know. any help?
Posted By: Doyledee
Date Posted: November 07, 2004 at 10:14 PM
Disconnect the speakers from their teminals, then replace the fuses. If is still blows them, you could have a bad amp.. If you know enough to take it apart, check for black residue around components or anything that looks smoked.....If the amp is bad you could take it to a shop to see if it can be fixed....or buy a new amp..... ------------- 97 Sebring Jx convertible
1500 RF amp with 2-10" Lanzar subs
2005 suzuki Katana 600
Posted By: Alpine Guy
Date Posted: November 07, 2004 at 10:25 PM
there on sale right now on sounddomain if its expensive to fix.
------------- 2003 Chevy Avalanche,Eclipse CD7000,Morel Elate 5,Adire Extremis,Alpine PDX-4.150, 15" TC-3000, 2 Alpine PDX-1.1000, 470Amp HO Alt.
Date Posted: November 08, 2004 at 12:03 AM
disconnected the speakers terminal and the still blew. im at a loss is there any other posilbilities?
Posted By: Ravendarat
Date Posted: November 08, 2004 at 1:24 PM
If you disconnect the rca's and speaker terminals and the fuses blow as soon as you replace them then I am gonna say that they amp has went the way of the egg...........................fried.
------------- double-secret reverse-osmosis speaker-cone-induced high-level interference distortion, Its a killer
Date Posted: November 08, 2004 at 1:28 PM
BTW how exactly did you wire up those subs to that amp, what load were you running
