I intend to put the following in my 97 crown vic:
Speakers:
Infinity Reference 6800cs -front
Infinity Reference 9603i -rear
Infinity Kappa Perfect 10 VQ -sub
Will place the sub in a Qlogic sealed .65
Power:
Infinity Reference 5760a 6 channel
Will bridge the two sub channels for a reported "56 watts RMS x 4 + 287 watts RMS x 1 in 5-channel mode"
My question is, with this sub, in this enclosure, will the bridged 287 watts be enough for good performance. I realize that 287 is ideal, probably at 14.4. I'll probably get less. Any ideas what I should expect? Is there a bare minimum % of RMS that should be provided to this sub, if so am I close? If anyone has any experience with this sub they will probably agree that the variables with this thing are extreme. It's got some removable inserts that change the magnets mass/strength, it will work in just about any enclosure.
Here's a good review
Sub Specs:
Impedance 4 ohms
Cone Material Magnesium Metal Matrix
Surround Material NBR
Sealed Box Volume (cubic feet) 0.3 - 1
Ported Box Volume (cubic feet) 1.25 - 2.5
Port diameter (inches) N/A
Port length (inches) N/A
Free-Air Yes
Dual Voice Coil No
Sensitivity 87dB
Frequency Response 25 - 0.4k Hz
RMS Power Range (Watts) 75-400
Peak Power Handling (Watts) 1600
Top Mount Depth (inches) 6 1/2
Bottom Mount Depth (inches) 7 3/16
Cutout Diameter or Length (inches) 9 1/4
Vas (liters) 45.88
Fs (Hz) 23.09
Qts 0.42
Xmax (millimeters) 16.75
You should be fine with that much power, but it probably depends on your listening habits. Try it, more than likely you'll be fine. If you start clipping the amplifier, you'll need more power.
New Project: 2003 Pathfinder
Thanks for the input. I must admit I am a bit nervous about this amp. The whole point was to keep my system to one amp for simplicity. If the sub is underpowered my whole plan may go out the door with this amp.
4 cylinders and two tires
You should be fine. I wouldn't be nervous about the amp, if you decide you need more power in the future you can always use that amp in a plan to upgrade speakers. bi-amp, run some midbass, etc.
