High/Low Level Converter
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=43128
Printed Date: May 17, 2024 at 12:42 AM
Topic: High/Low Level Converter
Posted By: donnie5336
Subject: High/Low Level Converter
Date Posted: November 16, 2004 at 2:56 PM
I have a Chevy with a Delco CD player. I've heard it has some sort of small built-in amp for the door speakers, and I think it does, because they sound better off the HU when I have it hooked up, rather than my Kenwood HU. My question is, if I get a High/Low conveter so that I can hook my amp up for subs with this factory HU, can I just tap into my rear speaker lines, or do I have to use those wires and disconnect them from my rear speakers? Also.. (I guess you can see I've never hooked an amp to a factory HU).. what do I do about a remote wire for my amp? Should there be a remote output wire on a factory radio, or is there one I can use? Thanks.
------------- Donnie
Date Posted: November 16, 2004 at 3:19 PM
nevermind about the remote wire...i'm an idiot...ACC wire...DUH! anyway.. if i just tap into my rear speaker wires for a LOC..will that be like running speakers in parallel and send a load of too low impedance to my HU?? if so.. is there anoyher option so that i can keep my rear speakers and hook up an amp to subs??
Posted By: spl-Hz
Date Posted: November 16, 2004 at 3:29 PM
We hook up high/low converters on factory radios alot and hve never had a problem running the speakers and the converter. Just make sure you use a quality high/low not some radio shack junk. Autotmotive Stereo & Alarm.
Date Posted: November 16, 2004 at 3:33 PM
they have one at circuit city in the car audio section for about $20.. but i dont remember the brand.. is that about the right price for a decent one?
Posted By: spl-Hz
Date Posted: November 16, 2004 at 4:57 PM
Soundgate, PAC, or audiolink are all good ones
