Alright guys..Figure my box is 5.3cu ft after sub displacement. How would i go from that figure into figuring out the dimensions of the box?? How do i get length/width/heigth from cu ft? Hopefully you understand my quesion. I'm a bit confused. Also I havenn't yet added in port displacement. Would i just simply add that number to 5.3?
Dave
Pioneer Premier DEH-P660
15" Kicker CVR
Profile AP1000M
It's Loud
Alright if you need 5.3 cu ft internal. find your port area let say for example your ports are .45 cu ft each. and your sub is .2 cu ft each so you would need to find a box that is 5.95 cu ft intenal. You need to find length x height x width that will give you a little more then 5.95 and then take the figures of the box external and figure them with length-3/4inch x width - 3/4 inch x height - 3/4 inch Subtracting 3/4 of an inch will take the wood into account. dont forget any bracing or deviding walls as well
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
