Mounting amp
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=43907
Printed Date: May 02, 2024 at 4:04 PM
Topic: Mounting amp
Posted By: bignissan
Subject: Mounting amp
Date Posted: November 27, 2004 at 2:46 PM
Should I mount the amp to a piece of plywood, then to the floor? Or is on the carpet ok? I think the plywood would help dissipate heat and prevent static build up...correct? Thanks!
Greg
Date Posted: November 27, 2004 at 2:55 PM
Also, on my Kenwood 608-S, by the RCA inputs, there is a screw that says ground. Do I need to ground that AND the other side next to the power wire? I hooked it all up, with out ground the little screw by the RCA's, and it worked fine, what's that for? Do I need to ground it? Thanks!!
Posted By: Klapping
Date Posted: November 27, 2004 at 3:43 PM
What i did... get sum sticky velcro stuff... like tape... and just tape the spike side onto the bottom of ur amp... and it should stick to the floor pretty well... does for me, at least... =)
Posted By: audiobass10
Date Posted: November 27, 2004 at 5:01 PM
basically...you can mount your amp anywhere you want..but give it a place where it can get air and stay cool...if you enclose it where it can't get air..make sure to include fans..ideal places to mount it would be in the trunk/cargo area,under a seat or even on the box..that's what i did on my last system.
------------- Dave
Pioneer Premier DEH-P660
15" Kicker CVR
Profile AP1000M
It's Loud
Posted By: astro88
Date Posted: November 27, 2004 at 6:05 PM
you can cut some small aluminum tubing to bout 1/4-1/2 long ,use them like spacers between the amp and floor, Looks a helluva lot better than plywood,imo, and good for air circulation
Posted By: stevdart
Date Posted: November 27, 2004 at 7:01 PM
Good idea there. Wood is an insulator, so it would help the amp retain heat...which you don't want.
Posted By: stevdart
Date Posted: November 27, 2004 at 7:04 PM
That's a convenience ground screw to connect the deck chassis with the amp in case you have a whine problem, or if you're using RCA's that have an attached ground wire.
