91 ford explorer stereo wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=46962
Printed Date: March 01, 2026 at 3:58 AM
Topic: 91 ford explorer stereo wiring
Posted By: rsudbay
Subject: 91 ford explorer stereo wiring
Date Posted: January 05, 2005 at 10:36 AM
i am installing a radio in a friends car. it is a 91 ford explorer. he has like 24 wires coming out the radio hole. supposably he has another friend try to install it and failed. but i have done acouple of radio. and i have never seen more than 15 wires back there. but my question is if i have a couple of wires. how do i test wires to find out wich ones are speakers. so how do you test for speaker wires? i have a multimeter and a continuty checker. but i dont know how to test for speakers. please help
hey, everyone has got to start somewhere. but ill learn
Posted By: DYohn
Date Posted: January 05, 2005 at 10:48 AM
Did you cut off the wiring harness plug?  Ooo, bad move.  Never do that, always purchase an adapter.  Here, this is all I know:  1990-91 Ford Explorer Stereo Information
Posted By: rsudbay
Date Posted: January 05, 2005 at 10:56 AM
when i got to the car all the harneses where already cut. but my question was how to test wires to find which one is the speakers? because none of the speaker wire colors in that diagram, match the wires in the car.
Posted By: DYohn
Date Posted: January 05, 2005 at 11:30 AM
Then the vehicle probably has the "premium sound system" with external amplifiers, so there are no speaker wires at the old HU location.  I recomend you purchase the Ford wiring diagram book for the truck.
In general, speaker wires in OEM wiring harnesses are matched color pairs, with one wire being solid and the other being striped.  Identify the pair (such as purple and PURPLE / white) and test continuity between them.  You should read 2 to 6 ohms.  Then you can "pop" the speaker with a battery to ensure you actually have a speaker pair and to identify which one it is.
Posted By: rsudbay
Date Posted: January 05, 2005 at 11:50 AM
DYohn] wrote:
p>Then you can "pop" the speaker with a battery to ensure you actually have a speaker pair and to identify which one it is.
how do you do that. just hook the positive to the positive side of a AA and negitive to a negitive??????
Posted By: KarTuneMan
Date Posted: January 05, 2005 at 12:09 PM
Use an old 9V battery.....much easier to hold, and NO it won't hurt your speakers.
