Boston Pro 6.52 Tweeter connectors?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=47049
Printed Date: February 27, 2026 at 9:14 PM
Topic: Boston Pro 6.52 Tweeter connectors?
Posted By: STRYKER124
Subject: Boston Pro 6.52 Tweeter connectors?
Date Posted: January 06, 2005 at 11:18 AM
I bought a set of Boston Acoustic Pro 6.52 components from a seller on ebay, and when I got them, I noticed that the connector on the back of the tweeters looks like it would accept only a tiny tiny spade connector.  These weren't included, and I was wondering where to get them?  I cut half off a horseshoe connector and wired the tweeters up with those long enough to test them with the woofers/crossovers, and the set sounds great, so I didn't get screwed, but I have no idea where to get connectors that fit properly.  I tried Boston's website, but it was less than helpful.
Any thoughts are appreciated.
Posted By: doughboy20
Date Posted: January 07, 2005 at 7:57 PM
Have you ever soldered?  You can solder the wire to the terminal.  And if you haven't , you can use a spade connector and before you slide it on the terminal, take some pliers and squeese on the connector so that the gap in the connector is real tight.  Slide it on and give it a couple of  tuggs.  If it stays on then your good to go.  Ifi it dosen't quite fit like you want it, try a car audio shop for the connectors.
1999 Chevy Lumina
Pioneer Deh-p6400 HU
2- Pioneer TS-W304C
2- Pioneer GM-X972 Amps
2- Pioneer GM-X572 Amps
All Pioneer speakers
4- Lightning audio 1 farad Digital Caps
And All Done By Myself
