any good pre-fab boxes?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=47827
Printed Date: May 12, 2024 at 1:43 AM
Topic: any good pre-fab boxes?
Posted By: sroth140
Subject: any good pre-fab boxes?
Date Posted: January 16, 2005 at 1:09 AM
im looking at obcon but they dont have the volume im looking for. i have made my own and love it but i dont want to go through it all again. im looking to run one 12" IDMAX D2 off of a Directed audio 2400d. ID says 1.33-1.53 sealed. any ideas come to mind.
------------- MECP certified installer
Posted By: auex
Date Posted: January 16, 2005 at 1:13 AM
Nope, don't know of any good prefab boxes. There is only one exception, but I improved it by building my own to driver's specs. I just looked for it but they don't make it anymore.
You can check these
RT Enterprizes
Obcon------------- Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Posted By: sroth140
Date Posted: January 16, 2005 at 1:17 AM
might be time to pick up another sheet of mdf then. its just too time consuming. i work on other peoples cars all day, i just dont want to do the work on my own now :( . but its time to get rid of that car and get a new one. i dont want to take up so much space in the new one so im going to a single 12" driver. thanks for looking. ------------- MECP certified installer
Posted By: auex
Date Posted: January 16, 2005 at 1:19 AM
I know what you mean, I have a fiberglass box in my trunk that I have put off finishing for over 3 years. ------------- Certified Security Specialist
Posted By: KarTuneMan
Date Posted: January 16, 2005 at 1:54 AM
With an IDMAX....you best build yer own box........ That sub will EXPLODE most prefab enclosures, givin the correct amount of juice.....JUST BUILD ONE......K
Posted By: Asmodeus
Date Posted: January 16, 2005 at 12:27 PM
Check out ProBox......https://www.proboxrocks.com/home.shtml Also may want to look at Audio Enhancers... https://www.audioenhancers.com I have used both of these companies for boxes and have never been disapointed.... ------------- Making the World A Louder Place
Posted By: spootydlux4
Date Posted: January 16, 2005 at 12:38 PM
proboxes are some bad ass prefabs. our shop uses them and if you get one to match your sub they will slam ------------- blah blah blah blah
Posted By: jeffchilcott
Date Posted: January 16, 2005 at 8:05 PM
I have a good prefab, I use it to sit on while I am taking a smoke break from building a real box
------------- 2009 0-1000 Trunk WR 154.0DB 2009 1001+ Trunk WR
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
Posted By: tjsxtremeaudio
Date Posted: January 16, 2005 at 9:31 PM
man your best bet is to build your own....at least if you do that you know what you've got i have always built my own boxes and i always will look and here is some advice go to www.linearteam.com and download win ISD pro...this program gives you acoustics and spl measurements aswell as other things...its a big help
Posted By: stevdart
Date Posted: January 16, 2005 at 9:56 PM
Look at Subzero as well. And I agree that you should also check out the specs and make sure the enclosure will be right for your sub.
Posted By: wheelerdr
Date Posted: January 16, 2005 at 11:06 PM
the obcon box is ok at best, i bought one to see how it was, because the owner of my store i install for wants some pre fabs to sell, I had to memphis 12, and up to punch stage 2 in it and it sounded really good, but when loaded with to punch stage3 the box was destroyed, rf's pl3 is the only prefab box that will hold up to the bass, but is only built for the rf subs. just build your own unless you want to go with another sub.
Posted By: pimpincavy
Date Posted: January 17, 2005 at 12:53 AM
Those Obcon boxes are pretty bottom of the line as far as prefab boxes go. Currently I have a subzone box, but im probably going to build my own box out of sheer boredom. Anyone ever hear of a prefab slot ported box called the "24 Pounder" I went to a shop today that had stacks of them everywhere.
