TWO DIFFERENT SUB IN SAME AIR SPACE
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=48519
Printed Date: May 09, 2026 at 7:32 AM
Topic: TWO DIFFERENT SUB IN SAME AIR SPACE
Posted By: rhdAndy
Subject: TWO DIFFERENT SUB IN SAME AIR SPACE
Date Posted: January 24, 2005 at 8:36 PM
I WAS JUST WONDERING IF YOU PUT 2 DIFFERENT SUBS IN THE SAME AIR SPACE WOULD IT HARM THE SPEAKERS, AND IF THEEY HAD THE SAME AMOUNT OF PWER WOULD IT BE SAFER.
Posted By: haemphyst
Date Posted: January 24, 2005 at 8:48 PM
if you are talking about 2 identical drivers receiving the same signal (from a mono amp or mono signal) then it is perfectly safe and acceptable to do so.
Posted By: michaelkontor
Date Posted: January 24, 2005 at 8:54 PM
rhdAndy wrote:
IF YOU PUT 2 DIFFERENT SUBS .
I have no Idea but I wouldn't think so.
Posted By: bluetruck
Date Posted: January 24, 2005 at 9:09 PM
no, dont mix sizes, brands, or models of subs. only if they are identicle and run on a mono signal. i dont mean to use a divider either, just use one or the other or get two that are the same.
