2002 explorer sound problem
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=48559
Printed Date: May 10, 2026 at 12:25 AM
Topic: 2002 explorer sound problem
Posted By: ccxccx2
Subject: 2002 explorer sound problem
Date Posted: January 25, 2005 at 12:39 PM
I added a amp an sub woofer to my stock radio.
Used the two rear speaker leads to make inputs to my amp........hardwired amp and added remote auxillary switch for power
Did not touch the Head unit or any of its wires, brought the system up and was powerful and the volume was really sensitive.
Everything seem to work, except for fine tuning and adjusting.  after it played for about an hour or two, i decided to start the truck to keep from totally discharging the battery.
The radio now does not produce any sound...its come on can change functions and you can see the volume level as you twist the knob but no sound from any speaket......... what happen,
checked fuses for the radio..they look ok but what else could have occurred........now i just have silence
is there a factory amp fuse or something to check......forget the the amp and subwoofer...i just want the sound back.
CC
Posted By: forbidden
Date Posted: January 25, 2005 at 12:56 PM
Check all of the fuses, even under the hood, not just ones that are for the cd player. There is a factory amp that is usually hidden behind the passenger rear quarter panel, close to the rear seat. This amp powers the entire system.
Posted By: ccxccx2
Date Posted: January 25, 2005 at 1:04 PM
Thanks Forbidden.  Are there any known issues that the amp cuold go out........ i was wondering if a polarity mismatch  could cause this....but that would only affect the new speakers...at least i think and would cause distrotion not a blow.
I also see post were people are bypassing the amp...could i just do that for the rear speakers if that is the case.
CC
Date Posted: January 25, 2005 at 2:14 PM
A polarity mismatch would not cause this. A speaker wire that is going to ground may cause the factory amp to shut down however. check the fuses first, then disconnect the wires at the point you attached them. If the system comes alive again then you have a problem with the connection or from the connection to the amp or in the amp itself.
Bypassing the factory amp is done when you are upgrading the cd player, not when you are adding a sub and amp to the factory system.
Posted By: ccxccx2
Date Posted: January 25, 2005 at 8:45 PM
You are right on the money!..I disconnected the inpute to the amp and the Radio came alive....so the factory amp is shutting down, but why does this continue to play when i reconnect them?  Well, if the speaker wire is going to ground...what exactly does that mean and how can i correct that.......sorry so many questions but i like to do this properly.
Thanks again!!!!
CC
Date Posted: January 26, 2005 at 12:30 PM
If one of the speaker wires that you attached is going to ground, it is shorting against the metal of the vehicle or another piece of equipment. Where exactly did you attach your speaker wires from the amps high level inputs to? Tell me that you also did not just take a speaker wire and put rca ends on them and pklugged them into the amp (very bad idea).
Posted By: spl-Hz
Date Posted: January 26, 2005 at 2:33 PM
I had the same thing happen in an 03 mercury cougar. Used the high level inputs on a MTX amplifier and the radio wouldnt produce sound until the high level was unplugged. My solution for the problem was to use a line level converter. The customer hasnt had a problem since.
Posted By: ccxccx2
Date Posted: January 27, 2005 at 2:55 PM
Again you are correct.  the RCA end came in the Amp install kit i got........seem to work ok until the problem occurred.  Why is that?  Is the solution as spl-HZ say.....i need line level converters install onthe speaker lines?
CC
Date Posted: January 27, 2005 at 3:53 PM
You do infact need a LOC, some good ones are made by PAC and Scosche or a super high end one that would give you way more flexibility is the Audio Control LC6 + bass remote.
www.audiocontrol.com
Posted By: ccxccx2
Date Posted: January 27, 2005 at 4:02 PM
You guys rock!!!!   i went to over Best Buy on my lunch hour and plugged in in in about 5 minutes.......its all good.   Man things sure have changed.....guess that why the audio guys get paid the bucks...........thanks again...!!!!!!!!!!!!!!!
CC
