Magnet Size
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=48581
Printed Date: May 10, 2026 at 9:51 AM
Topic: Magnet Size
Posted By: tackett834
Subject: Magnet Size
Date Posted: January 25, 2005 at 4:44 PM
Hey guys, im new to the site.  This seems like a great place to answer all my questions and learn a lot of stuff.  Anyway,  i got a question.......What does the size of the Magnet have to do with the actual sub?  Does it make it hit harder or what?
Also, I plan on building my system when the income tax check comes in.  I want a system that people will hear me comin from a distance.  I used to have  Rockford Fosgate Rockbox with 2 15s in it, but that system wasnt great.  I have an extended cab full size chevy, so space isnt a big deal.  I dont want to spend too much on it either.  SQ isnt that important to me, but I do want it to sound decent.  I was thinking about the Audiobahn DUB series subs, but havent heard much on them.....but you guys gimme your suggestions on subs (different brands) and sizes and what you do. Thanks guys!
Posted By: /R7
Date Posted: January 25, 2005 at 5:32 PM
you probably havent heard much from audiobahn because they dont have much to boast about, unless as the old joke goes, you like the chrome.
Are you planning to buy locally? and if so - what brands are around your area. if not, and you dont want to spend all that much - i hear good things from image dynamics, and they also dont require a big box. Adire Shiva's are also a great sub for the price, and if you want more than that, the Brahmas are raved about.
What is your power situation right now? what amp(s) do you have to put in, and what do you want to put in as far as power, that may persuade which sub you should opt for.
i think 2 15's will be plenty loud, but if your saving a buck, and dont mind a -3db drop, get 1 15" or 1 12". with a ported enclosure (if your up for the task of building that sort of box) you can get some nice results for loud & low sound.
if you are wanting to stick to local dealers, let us know what brands they carry, otherwise telling you to get an Adire sub, or ID sub will not help you in any way.
Posted By: Steven Kephart
Date Posted: January 25, 2005 at 6:10 PM
You can't judge a speakers performance on it's magnet size.  Also be sure to ignore efficiency numbers and power handling numbers in comparing a speakers quality.
Steven Kephart
Adire Audio
Date Posted: January 25, 2005 at 6:30 PM
I plan buying from the internet.  The only speakers around here locally are JL, Kicker, and Alpine.  Thats about it.  Also I plan on pushing how ever many watts it takes to get a sweet thump.  Also like i said, i have an extended cab truck and i dont care to remove the back seat,  so i have plenty of room.  Oh yea, another quick question....what about 18" speakers?  What are your comments on them?  Thanks guys
i need the link to the Brahma sub if someone dont mind
Date Posted: January 25, 2005 at 6:41 PM
i checked out some subs from adire audio.....wow.  I am looking ang the 15" Tempest.  Do you think it will do what i am looking for?  I just want people to hear me comin from a distance. Thanks
Posted By: uthinkuknoaudio
Date Posted: January 25, 2005 at 7:57 PM
lol, well that didn't work out well. Anyways, 18" woofers i can recommend are Cerwin Vega Strokers, if you want loud as hell that is the ticket. Or of course you can get Juggernaut 18"s :)
"I don't play games. I play Nakamichi and that for real yo" - Probably some japanese kid said this in the early 80's trying to sell stereo out of his trunk lol.
Posted By: Poormanq45
Date Posted: January 25, 2005 at 8:25 PM
Agreed. Go with the strokeers. They retail around $250~$450. That's half the price of most 18 in subs.
Posted By: pimpincavy
Date Posted: January 25, 2005 at 8:32 PM
Strokers are a good idea, you can also look at resonat engineering,or digital designs subs, the kicker L7 gets really loud to.
Posted By: stevdart
Date Posted: January 25, 2005 at 8:37 PM
https://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=299-660
Your money will be in the amp to power it.
(It's a Kove Armageddon)
Posted By: petergozinya
Date Posted: January 26, 2005 at 12:16 AM
my experience with an 18 was great ! It was my first system. I built the biggest box i could (ported) and stuffed it into a haundai exell . sub was by earthquake. Box was me mesuring and my hommies cuting. My girl said she could clean the whole house before i made it to the driveway. It was the lowest material i have ever experienced . Those low wave's from an 18 will travel very far.(when all else is an accord)
good luck , thad
Posted By: 97Avalonxls
Date Posted: January 26, 2005 at 11:30 AM
I would say go with some kicker l7's, they are a pretty good SPL sub, are fairly cheap, and if you can get them locally, you'll save on shipping. that Kove from part express is also a guarenteed winner.
<petergozinya> I don't understand the last two lines of your post
Date Posted: January 26, 2005 at 3:44 PM
Sweet....i think i will get that Kove.  Should i get two of them of just put 1 of them in a ported box?  What kind of amp will i need also? Thanks
Posted By: stevdart
Date Posted: January 26, 2005 at 7:55 PM
If you can't get a sweeeet thump with one, then something was done way wrong!  You will go into a completely different realm of cost if you get two.  Here's why:
The sub is 4 ohm DVC, which is a 2 ohm load with the coils in parallel.  You can power it with a dedicated one-channel amp at 800 watts.  If you use two, the wiring of the two will combine to a 1 ohm load....which means that the amp you choose not only has to have very high output but also be a high-current 1 ohm stable piece of equipment.  The power requirements of your truck will be increased considerably, too, with the need for larger wiring, bigger fusing, and a more robust alternator.  Enclosure is twice the size, too.
Maybe sometime down the line after you get more into the hobby, you can set your truck up for competition use.  But for the first time I would suggest getting one and doing a super install.  You will still possibly need an alternator upgrade, but you can see if that need arises.  You will also gain by searching the forum for opinions on wiring upgrades....read through the "ground" forum for tips......etc.
For amp choices, there are several....really many.....that I would be happy with.  Choose quality brands that are recommended on this forum.  Look for the "mono amp" class to power this sub, with output of about 500 watts into 2 ohms.  One that immediately comes to mind is the Hifonics BX1000D.  Good bang for the buck.  This particular amp is also capable of the high current 1 ohm load I spoke of.  You'll have more questions on subjects dealing with the setup and install after you've made your choices and received the gear, so keep taking advantage of this good company here.  We all like to put our thoughts out.
BTW, I would use this sub in a vented enclosure for the type of output you want.
Posted By: heavilymedicate
Date Posted: January 26, 2005 at 8:50 PM
Just a tack-on to what stevdart said...
If you use a ported enclosure get an amplifier with a subsonic filter because when you try to play below the tuning frequency you may damage your woofer.  The frequencies typically found on bass... ummm, "music"?... will often hit below the tuning frequencies of most subwoofers.  Unless you like replacing woofers...
The Hifonics BX1000D does have a variable subsonic filter, variable is preferred as it allows you to match up to your subs tuning frequency.
One of those woofers would POUND, I have no idea what you could do with 2.. Kids...
Get a alarm and please "boom" responsibly.
What will you get for Christmas, bad boy? Coal........or Visonik?? - stevdart
Wow, is everyone clueless and lost in the dark? - uthinkuknoaudio
Posted By: haemphyst
Date Posted: January 26, 2005 at 10:22 PM
For those of you interested in building a TL, this'd be tha driver to try it with! This thing'd ROCK you A$$ OFF! I have already ordered two, as I need some subs for my home system!
Date Posted: January 27, 2005 at 1:09 AM
That's a pretty high Fs on that thing, especially for a HT.  I'd recommend adding some mass to that cone to drop it some.  I'd rather have the low end than the efficiency.
Steven Kephart
Adire Audio
Date Posted: January 27, 2005 at 3:40 PM
Thanks a lot guys.  You have really helped me out here.  Last night I kept looking at the Adire Audio Tempest 15".  It seems really good too.  So now once again I am struck with a choice between the Tempest 15 and the Armageddon 12.  Which one would be louder in a vented box...?  Thanks guys
Also I am a big rap listener.....so a vented box would be correct...right?
Posted By: customsuburb
Date Posted: January 27, 2005 at 3:57 PM
The Armageddon might be able to get a little louder since you have probobly have to give it around 700 to 800 watts continuous at least. A tempest would probobly be fine with 400 to 500 watts probobly though so you wouldn't have to spend as much on an amp.
Date Posted: January 27, 2005 at 4:34 PM
Ok.  Now how does this Ohm stuff work?  Say I am going to purchase for example a Dual Voice Coil 4Ohm sub.  Do I need a Mono-Channel amp or a 2-Channel amp?  Also on the specs of a 1000 watt mono amp, it says
                1000 x 1 @ 1ohm      500 x 1 @ 2ohm        250 x 1 @ 4ohm
So does the amps have a switch to choose how many ohms or what?  Do you have to have the amp 4ohms for a 4ohm speaker? Thanks bunches
Date Posted: January 27, 2005 at 4:43 PM
The speakers impedance determines the ohm load on the amp. Sorry thats not the best way to explain it but here are some diagrams of how you could wire a single 4 ohm Dual Voice Coil sub.
posted_imageThis is how you would wire the woofer in parallel.
posted_imageThis is how you wire it in series.
Date Posted: January 27, 2005 at 4:55 PM
Thanks a lot man.....which is better...parallel or series wiring?  Also I see that the Adire Audio Tempest is a 8ohm DVC sub according to https://www.speedsound.com/caraudio.asp?pg=products&specific=jmroomhmk
So would a mono amp still do the job...or the 8ohm load in the picture above (wiring in series) work? Thanks
Date Posted: January 27, 2005 at 5:02 PM
You will want to get either a high powered 2 channel amp (400 to 500 watts continuous at 4 ohms) or a class D amp that puts out 400 to 500 watts at 4 ohms also. Just wire it in parallel if you are wanting to get a 4 ohm load.
Date Posted: January 27, 2005 at 6:49 PM
Steven Kephart
Adire Audio
Ahhh... maybe so, but if you actively cross it over BELOW the Fs of the driver (I was thinking about 28Hz - the F3 of my existing system) and allow the TL to extend the frequency response, you CAN get away with it - WITHOUT adding mass. I was figuring on a stuffef line tuned for around 18, which by my calculations SHOULD dump the F3 of the system right around 20. I say this, because experience dictates that no matter WHAT frequency you aim for, your tuning will almost ALWAYS end up about 1/2 octave below that, due to frictional losses in the line... Not a bad way to shift the response though, hmmm?
Posted By: bullman96
Date Posted: January 27, 2005 at 7:12 PM
how does the armageddon sound besides being loud as all hell?
Date Posted: January 27, 2005 at 8:40 PM
dunno... probably like crap unless it is powered properly. LOL
Posted By: Bjuniord
Date Posted: January 30, 2005 at 1:07 AM
Dude, I just had to share this experience with my 18" Cerwin Vegas:
The box was the whole back seating area of a '76 Honda CVCC Civic (I think the smallest Honda ever made) - we built the box inside the car and was big enough so ports wasn't even considered. They were powered by a Rockford Fosgate Punch 800 - that was wired mono giving each of the pair 400W of continous power. Talking about boom - you didn't hear my music, you felt it - 5 blocks away! Use to rattle everything off convience store shelves for kicks. Your vision was actualy impared while getting a back massage. And, I use to joke that when ever I ran out of gas, I'd open the hatch and get basspropellsion.
Jr
