six speakers and one amp how?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=48734
Printed Date: May 12, 2026 at 12:05 PM
Topic: six speakers and one amp how?
Posted By: pepecajetas
Subject: six speakers and one amp how?
Date Posted: January 27, 2005 at 2:12 PM
well it goes like this:
Pair of 6x9 rated 100 rms each
Pair of 6 1/2 component rated 120 rms each
Pair of 8 subwoofers rated 130 rms each.      All of them rated 4 ohms
One Amp:  4 channels 100 RMS per channel, bridgeable.
Need your advice in how to wire to obtain the get the best of this.. thanks a lot
Posted By: fuseblower
Date Posted: January 27, 2005 at 3:51 PM
If your amp can tri-mode you can wire all of your speakers to your amp and shouldn't have a problem.  You have to purchase some capacitors and coils and make a passive crossover or you can just wire them in-line on the speaker wire.  It all depends on what type of look you are looking for.  see the 12 volt link below.
https://www.the12volt.com/caraudio/cross.asp
Posted By: customsuburb
Date Posted: January 27, 2005 at 4:11 PM
Which ever set of speakers you are using up front I would use with the amp (I hope its the 6 1/2 components). Then I would use the lowpass crossover on the rear channels and connect the two subs to each channel. Power the 6x9s off of the deck in back and it should sound good.
Posted By: Francious70
Date Posted: January 27, 2005 at 4:53 PM
Ditto on customsub's reccomendation.
Paul
Date Posted: January 27, 2005 at 5:50 PM
I was thinking on parallel wire each pair of 6*9 and 61/2 then connect them to 2 amp channels letting the 2 channels left for subs... is this possible?
Posted By: stevdart
Date Posted: January 28, 2005 at 4:35 PM
You mean to parallel-wire the right side, and same with the left side, to keep your music in stereo.  It's possible but a bad idea.  The amp will be powering the speakers at a 2 ohm load....okay for low freq subs but not for the mids and highs.  It won't kill the amp or the speakers but will result in less than ideal sound.  And, you wouldn't be able to fade the rears as all speakers will get the same volume.  So I'm also with customsuburb on his recommendation.  But I would link the subs in series, then bridge across two channels for the same output as would be with a sub on each channel.
Posted By: jeffchilcott
Date Posted: January 28, 2005 at 7:02 PM
I would go the way customsurburb mentioned.   I would rather have full power to the fronts and subs and worry about the 6x9's last
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
Posted By: Poormanq45
Date Posted: January 29, 2005 at 7:04 PM
Ditto what customsuburb said.
To add to that: Bridge the four powered outputs from your HU into two channels. This should give you enough power to power your rear speakers.
Date Posted: January 29, 2005 at 7:18 PM
Don't try to bridge a deck's speaker outputs. It can fry your amp easily. Just connect the 6x9s to the rear speaker outputs if you are using them in the rear. They should only be used for a little added bass and rear-fill anyways. The soundstage should be up front, not behind you.
Date Posted: January 29, 2005 at 7:22 PM
Some decks can handle bridged outputs. Some cannot.
What HU are you using?
Date Posted: January 29, 2005 at 8:05 PM
It should damage any deck that you try it with. Read about it here: https://www.bcae1.com/brighead.htm
