battery drain
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=54201
Printed Date: February 13, 2026 at 1:09 AM
Topic: battery drain
Posted By: Deusqe
Subject: battery drain
Date Posted: April 19, 2005 at 12:19 AM
what's up everyone,
i got an amp running two subs @ 500 rms. If I were to simply turn the key to the accessory point (dont turn on car), about how long would i be able to play music at 3/4 volume. I've got a standard battery, nothing special.
don't rush into things...you'll get ripped off
Posted By: sedate
Date Posted: April 19, 2005 at 12:53 AM
Assuming a half-way decent amp, you ought be able to run that anywhere from 10 - 30 minutes before being unable to start your car.
Word to the wise - don't try it - draining off a standard SLI battery is a good way to drastically shorten both its reserve capacity and operating life.
If you want to play ur stereo, bite the $2.50/gallon and idle ur car. posted_image
Posted By: sedate
Oh yea, nice sig.
Posted By: Deusqe
Date Posted: April 19, 2005 at 11:14 AM
Thanx for the reply +compliment.
looks like it will be idling.
