St-500D 1 ohm stable?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=54999
Printed Date: May 12, 2024 at 1:35 PM
Topic: St-500D 1 ohm stable?
Posted By: AJRXtreme
Subject: St-500D 1 ohm stable?
Date Posted: May 02, 2005 at 7:19 PM
I have a memphis 500D and i want to know if its 1 ohm stable. I want to power my 2 10" dual 4ohm mclass's at 1 ohm. Thankyou
------------- 03 F150 on 24's
HU:Pioneer DVD5700
Frt:MC57
Subs:(12)S12L7
Amps:(3)KX2500.1's, MC-2004
Posted By: KarTuneMan
Date Posted: May 02, 2005 at 8:17 PM
will not work under a 1ohm load....not for long anyhows.............
Date Posted: May 02, 2005 at 10:39 PM
so all i can do is a 4ohm load?
HU:Pioneer DVD5700
Frt:MC57
Subs:(12)S12L7
Date Posted: May 02, 2005 at 10:59 PM
2ohm...for all the power this little thing can give
Date Posted: May 03, 2005 at 3:11 PM
well im not able to wire my subs down to 2 ohms. Only 4 ohm or 1 ohm.
HU:Pioneer DVD5700
Frt:MC57
Subs:(12)S12L7
Posted By: kfr01
Date Posted: May 03, 2005 at 3:24 PM
Keep it at 4-ohm. Don't go to 1-ohm.
You -could- buy another 500D and use one amp per subwoofer at 2-ohms. That would greatly increase your available power and keep both amplifiers within their comfortable range.
The only thing you'd have to worry about then is -overpowering- your subs. Take care with your gain and with your volume knob on the receiver and you'l be fine... and running with some nice headroom.
------------- New Project: 2003 Pathfinder
Posted By: haemphyst
Date Posted: May 03, 2005 at 8:10 PM
Are you talking about the 16-PRD500.1? Yes, it is one ohm stable, but I would recommend another amp, and run them each at 2 ohms... they'll last longer... ------------- It all reminds me of something that Molière once said to Guy de Maupassant at a café in Vienna: "That's nice. You should write it down."
Date Posted: May 03, 2005 at 9:51 PM
its the 16-St-500D (studio class)
HU:Pioneer DVD5700
Frt:MC57
Subs:(12)S12L7
Posted By: kfr01
Date Posted: May 04, 2005 at 4:30 AM
Woops, sorry. I thought you had the mclass for some reason.
I like my original advice. Get a twin and run them both to one sub. :-)
