96 Ford Windstar CD Player
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=55240
Printed Date: May 29, 2024 at 6:05 AM
Topic: 96 Ford Windstar CD Player
Posted By: btlgrl
Subject: 96 Ford Windstar CD Player
Date Posted: May 06, 2005 at 1:58 PM
Help!  I am trying to replace my piece of crap factory cd player on my 96 Ford Windstar.  The CD player has NEVER worked, it clicks constantly and only plays the 1st 3 or 4 tracks of every cd, that is if it even loads.  I decided to replace it, just so I don't have to carry around 60 cds for 3 cds worth of tunes.
I bought 3 different wiring harnesses, and an FAI.  From my dash I have the rectangular flat pin cable(hooks up to the wiring harness fine, although I cannot figure out where to stick the orange illumination wire and I am guessing I don't need to hook up the solid blue wire for power antennae if I don't have a power ant.)  Power is going to stereo, as I can eject a cd, but no display, no cd spin, etc.  I also have a smallish 2 pin cable witha  tan and lt blue/pink wire.  This is for rear radio control.  No biggie, never used this feature. I have 2 speaker grey speaker cables.  One is a square 8 pin, the other a square 6 pin.  The 8 pin hooks up fine in the wiring harness.  The 6 pin I cannot find any harness that it can hook to?!  I tired the factory radio without the 6 pin, and it will only function with both 8 and 6 pin speaker cables.
I read on installdr that I needed a Ford Integration Wire harness for premium sound amplifier bypass?!  I cannot find one that will accomodate a 6 pin square speaker cable.  I just want to be able to listen to a cd all the way through....
Can anyone help?  What do I need to do?  Do I neeed to keep that darn FAI?!  Any assistance would be greatly appreciated.
Posted By: tcss
Date Posted: May 06, 2005 at 3:40 PM
All of the things you are looking at are not the problem. The rear headphone jack is common grounded. Meaning the stereo's four speakers share a single ground wire. You need to run new speaker leads to all six speakers and wire them to the stereo.
Posted By: harvey1959
Date Posted: May 07, 2005 at 2:25 AM
I have a 98 Windstar.  I brought a wiring harness from WalMart of all places and it works fine. You don't need the FAI.  There should be 3 harnesses coming off of the factory radio.  The flat one you already have hooked up, The small one for the rear control to the radio, just tape that up.  The orange wire, just tape that up.  You should have another small jack, probably the six wire you were talking about.  Your harness should fit that.  it may be real tight, but you don't need an integration harness. If it doesn't fit you may have the wrong harness.  Do you have 4 speakers or 6 in your van?
Harv
Posted By: btlgrl
Date Posted: May 07, 2005 at 6:45 AM
I have 4 harnesses coming from the van.  I have bought 3 different harnesses from WalMart which all specify premium sound Ford vehicles.  Not a single one has fit that darn 6 pin.  The 8 pin is a real tight fit, but it works fine.  One of the harnesses I bought even had 5 different ends, but not a single one was even close.  I can't seem to find a single person who knows what I'm talking about with this second speaker cable.
I thought I had 4 speakers, but I could be wrong...
Posted By: mobileworks
Date Posted: May 07, 2005 at 7:22 AM
There is sometimes the small square 8 pin plug (these are the speaker wires or should I say low level signal to the factory amp)
Then there is a same style of plug but with only 6 pins (this is usually for headphone jacks and other crap)
Then there might even be a small single pin plug, and last there should be the long single row of pins that is usually grey in color.  This grey one is power and dimmer, illumination and ground
You'll need to make sure that the red and yellow wire has power when the key is turn on....both have to have power in order for the radio to turn on.  If your not even getting the radio to power up, start there.  Don't use a test light because a test light will show voltage however it will not show voltage amount and some times poor connections have the ability to drop the voltage down to a point that the radio will not turn on, but the light turns on and makes it look like it has power.
Anyways if your getting the radio to turn on next you will need to make sure that the amp turn on wire in your wiring adaptor is connected (blue/white trace)  Make sure this is connected to the amp turn on output of the radio.  This wire supplies power to the factory amp and is the only way your going to get power out of amp.
Hope that helps.
Posted By: btlgrl
Date Posted: May 07, 2005 at 3:02 PM
That is great help!
Ok so I have power to the unit.  What do I do with that blasted 6 pin?!  I have no sound.  I have the 8 pin and the flat rectangular hooked up, smallish rear control taped up.  but without that 6 pin it won't work.  The factory won't even work without both 8 and 6 pin connected.  I have looked at so many wiring harnesses I am cross eyed.  Does a wiring harness that accomodates a 6 pin exist?!  maybe another make?!
Thanks!
Posted By: azhrei
Date Posted: June 10, 2005 at 12:27 PM
but where is the amp located?  sorry for the notejack!
