Wire Harness
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=55547
Printed Date: June 09, 2024 at 1:58 AM
Topic: Wire Harness
Posted By: meh66
Subject: Wire Harness
Date Posted: May 11, 2005 at 3:09 PM
Does anyone know who makes a wire harness that plugs into an after market head unit and the other side plugs into another harness that plugs into the vehicle harness? I seen one but the person could not tell me who made the harness.
------------- MEH66
"Car Performance and Mobile Electronic Enthusiats"
Posted By: dwarren
Date Posted: May 11, 2005 at 3:13 PM
metraonline.com
Posted By: meh66
Date Posted: May 11, 2005 at 4:10 PM
Thanks....are you sure it is metra? The metra harnesses I have been installing require you to wire it to the after market radio harness. I believe it was two harnesses..one plugged directly into the after market radio and the other harness plugged directly into the first harness and then plugged directly into the car factory harness.
------------- MEH66
Posted By: dwarren
Date Posted: May 11, 2005 at 4:21 PM
Well if I am mistaken, call a circuit city or best buy. They utilize those, I remember selling them at CC, way back when.
Posted By: Chad7n7
Date Posted: May 11, 2005 at 5:06 PM
Metra does make these, most shops just carry the into car harness, but you can get the harness you are inquiring from Metra, or your local shop can order it for you.
Posted By: OhioMike1101
Date Posted: May 11, 2005 at 10:02 PM
we carry a couple at my shop. They are Metra. We carry the JVC and Pioneer ones for GM cars since that is what we do the most of. dealer cost is 5X as much on the normal harness though.
Posted By: kgerry
Date Posted: May 12, 2005 at 9:34 AM
they are part of Metra's "SmartCable" line... we use lots of them here...one side plugs into the aftermarket deck and one end plugs into the car... finished... they also make some OEM smart cables so you can plug an older GM radio into a newer GM vehicle, etc......
------------- Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Posted By: meh66
Date Posted: May 12, 2005 at 10:25 PM
thanks everyone
------------- MEH66
Posted By: accord_coupe01
Date Posted: May 14, 2005 at 3:48 AM
I checked metraonline.com and couldn't find one for a 2001 accord do they make it for this car?
