99 chevy silverado stereo
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=55686
Printed Date: May 29, 2024 at 6:23 AM
Topic: 99 chevy silverado stereo
Posted By: qmw54
Subject: 99 chevy silverado stereo
Date Posted: May 13, 2005 at 6:55 PM
i have a 1999 chevy silverodo and i plan to put/replace speakers and i need to know what color the rear speaker wires are and also does any one know how to remove the door panels with out breaking the clips that hold them to the door ... thanks qmw54
Posted By: geepherder
Date Posted: May 13, 2005 at 8:18 PM
https://www.the12volt.com/installbay/detail.asp?info=alarm&year=1999&make=Chevrolet&model=C/K%20Pickup&ID=17379&type=Stereo Once all the hidden screws (7mm) are removed, lift the panel up, then out and it'll come. ------------- My ex once told me I have a perfect face for radio.
Posted By: midnight wolf
Date Posted: May 13, 2005 at 8:28 PM
I have a 2001 Sierra which is basically the same truck. In mine the rear doors there is two screws.. on is in the cup holder the other one should be visible i cant recall exactly where it was at... take those two screws out and pull on the panel it should pop right off the plastic tabs holding it in. The front door was a little different. I had to take out the switches for the windows and locks ...there is one screw hidden under the switches and the other screw is near the handle. Take those two screws out and lif up and the panel should pop right off. Hope that helps
Posted By: qmw54
Date Posted: May 13, 2005 at 9:26 PM
if i remove the 2 screws will i break any clips that hold the pannel to the door ??
Posted By: spootydlux4
Date Posted: May 14, 2005 at 10:43 AM
yea if you're not careful. make sure you take off the plastic piece around the door handle on both doors, the little triangle piece by the mirror on the front door. and the manual door lock u will need to pop off. also be careful when you pull up on the door panel becuz there will be wires goin to the speakers, the vanity light, and seat heaters if you got em. and if you want to do sumthin fun while the door panels are off, take off the speaker grille and clean up the amazing amount of dirt you will find!
------------- blah blah blah blah
Posted By: qmw54
Date Posted: May 14, 2005 at 2:18 PM
ok cool thanks yalll.... i am gonna try to do it today
