running two car batteries
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=57633
Printed Date: June 07, 2024 at 10:09 PM
Topic: running two car batteries
Posted By: slicksteveo
Subject: running two car batteries
Date Posted: June 13, 2005 at 8:21 PM
i was wondering how to hook up to car batteries in my car i need to rn two b/c the one i have the head lights dim and i have a cap.  do u have to have a battery isolater to hook up two batteries or is there a better way to do it.  ive tried two battery isolaters and neither of them have worked.  you input would be greatly tanked so i can get my system back up and running.
Posted By: ss-installer
Date Posted: June 13, 2005 at 8:41 PM
try have the alternator rewound to HO at a local rebuild shop. if the alternator isnt big enough to produce enough power to 2 batteries then it wont do ant good.
Date Posted: June 13, 2005 at 10:35 PM
the alternator is plenty big to charge two batteries i just need to know how to run the wires
Posted By: haemphyst
Date Posted: June 14, 2005 at 12:53 AM
OK, slick...
1: Just wire them in parallel. Forget any isolation techniques - this means solid-state diode types and relay types... leave them at the PepBoys accessory desk. I will not go any further with that - just don't use them... If you want to read further, check out this thread...
2: Dual batteries will do you NO GOOD WHATSOEVER without an alternator large enough to power the entire car as though there were NO batteries in it. Your amplifiers do not run off the batteries, they run off the power produced by the alternator. Get an HO alternator, before you go spending money on a second battery. If you ask again, you will get the SAME answer from everybody that knows what they are talking about on this board.
