bridging thick wires into small terminal?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=57674
Printed Date: June 08, 2024 at 6:42 AM
Topic: bridging thick wires into small terminal?
Posted By: PuppyDawg
Subject: bridging thick wires into small terminal?
Date Posted: June 14, 2005 at 11:59 AM
Just curious.... How do you guys go about bridging thick speaker wires into a terminal that's too small? Thanks in advance....just wanting to know different approaches towards this.... ------------- *paw print*
Posted By: DYohn
Date Posted: June 14, 2005 at 12:03 PM
Use smaller speaker wire... in a car there is really no need to use speaker wire larger than 16 gage in any case, unless it's simply for looks. ------------- Support the12volt.com
Date Posted: June 14, 2005 at 12:17 PM
really?...interesting...another question....what if these speakers are 2 15" MTX Thunders (8000 Series)? same theory? thanks man! ------------- *paw print*
Posted By: oonikfraleyoo
Date Posted: June 14, 2005 at 12:28 PM
He did say any case didn't he? Unless your 1000+ watt amp is under the hood and your speakers are in the trunk then never. ------------- Nik
Jeeputer Progress
[|||||||||||-] 90%
Check it out.
Date Posted: June 14, 2005 at 12:31 PM
coo...thank you gentlemen....i appreciate it..
Posted By: DYohn
Date Posted: June 14, 2005 at 12:47 PM
Same theory. ------------- Support the12volt.com
Posted By: Poormanq45
Date Posted: June 14, 2005 at 3:36 PM
The theory is right about not generally having to use anything larger then 16gauge, but I personally prefer to use 12 or 14.
This is probably becasue I'm so used to working with home stereos where the runs can be rather long.
Just be safe, go with 14gauge, it's only $1 more at walmart
Posted By: Alpine Guy
Date Posted: June 14, 2005 at 8:17 PM
i run 2400 wrms through 14 awg......, no problemo's.
------------- 2003 Chevy Avalanche,Eclipse CD7000,Morel Elate 5,Adire Extremis,Alpine PDX-4.150, 15" TC-3000, 2 Alpine PDX-1.1000, 470Amp HO Alt.
