confused about crossover
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=58211
Printed Date: February 07, 2026 at 8:18 AM
Topic: confused about crossover
Posted By: tinter
Subject: confused about crossover
Date Posted: June 22, 2005 at 2:39 PM
hi, im installing a MTX rt-x01a, i cant understand why it has one rca imput, one set of left and right speaker wire inputs, but two rca outputs, which should both go to the single rca input on the amp. do you  think you can help me understand? thanks
Posted By: DYohn
Date Posted: June 22, 2005 at 3:08 PM
It's a 2-way crossover.  It splits the incoming signal into two signals, crossed over at frequency setpoints you can select, to connect two different amplifiers.
Posted By: Nodestiny
Date Posted: June 22, 2005 at 3:16 PM
yeah, usualy one is low pass and one is high pass. So you can select a point for say an amplifier that will goto subwoofers and an amplifier that goes to tweeters (or midranges, or whatever). You can do many combinations, midbass and midrange/treble, bass and treble, bass and midrange/treble... you name it!
04 dodge neon SXT
(2) Oz Audio Matrix Elite 12"s sealed in 4 cube fiberglass enclosure, powered by HiFonics BX1605D
Oz Audio Matrix 180cs 6.5" component set power by HiFonics ZX4000
Posted By: tinter
Date Posted: June 23, 2005 at 9:45 AM
which speaker wires from the HU do i use to go into the crossover? the ones for the rear speakers?or do i not need them .thanks again
Posted By: DYohn
Date Posted: June 23, 2005 at 1:26 PM
How are you trying to use the crossover?  It will accept speaker-level inputs, but what are you trying to use it to accomplish?
Posted By: tinter
Date Posted: June 23, 2005 at 1:32 PM
he says he wants to be able to adjust the audio sound quality
Posted By: DYohn
Date Posted: June 23, 2005 at 2:42 PM
Uh...... then you don't want a crossover.  Who is "he" and what does he mean by "adjust the audio sound quality"?
Posted By: tinter
Date Posted: June 23, 2005 at 4:05 PM
sorry dyohn "he" is my friend that iam doing the install for, I' v hooked up many HU and amps, but never a crossover before, have we been misinformed to what the crossover actually does?thanks
Posted By: dwarren
Date Posted: June 23, 2005 at 4:08 PM
I think you guys are looking for an equalizier, a device that allows you adjust certain frequencies, hence your statement above about adjusting the sound quality.
They sometimes look similar.
Posted By: DYohn
Date Posted: June 23, 2005 at 5:12 PM
Yea, I agree, probably you want an EQ.
A crossover can sometimes improve sound quality by limiting the bass in to your main speakers, keeping them from playing frequencies they have a hard time with.  But it's designed to be installed and left alone.  A crossover splits the audio spectrum into multiple signal paths depending on the frequency of the sound.  It sends the bas to the woofers and the mids to the mids and the treble to the tweeters, putting it simply.  In the case of the MTX you have, it is designed for a HU without a sub woofer pre-out so you can create one using the front or rear outputs.
