amp channels?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=58254
Printed Date: February 06, 2026 at 3:01 PM
Topic: amp channels?
Posted By: Jmeese
Subject: amp channels?
Date Posted: June 23, 2005 at 11:32 AM
Question regarding matching speakers and the # of channels of an amp. Just replaced head unit in 2002 liberty with Kenwood KDC-Mp828. Has front and rear speaker wires coming out of the unit. I have 6 speakers currently. I'm assuming the front is running the dashboard and the front doors and the rear is running the rear. When I hook an amp can I get away with a two channel one channel running the fronts and one running the rears? Also since I am going to be using a component speaker system will this method send to much power to the tweeter and blow them?
Posted By: dwarren
Date Posted: June 23, 2005 at 12:22 PM
First off you will need a four channel amp to run four speakers. Secondly a passive cross over is mor than likely in place in the front between the tweeter and mid-bass driver. The x-over will require one input from the amp then has two outputs for the two speakers. There will obviously be two x-overs, one per side.
The x-overs will "protect" the tweeters from playing frequencies that wil harm it, but you still can blow any speaky with improperly set gains.
These are factory speakers?
Posted By: Jmeese
Date Posted: June 23, 2005 at 1:37 PM
Currently factory speakers with Kenwood KPC MP828. I'm going to replace the 2 in the dash and 2 in the front door with a component set. However the speaker wire coming from the deck only has front and rear (two wires labeled for each). Do they have the 2 speakers in the dash and the 2 in the front door running off of the front (two wires from head unit). I'm not sure how I have 6 speakers running off of this with only a front and rear cables. I'm looking for a little louder sound. Would just upgrading to compont speakers with a higher rms wattage accomplish that? Or would I need an additional amplifier? I was thinking of adding either an amp for the speakers or a amplified subwoofer. Plus trying to go on the cheap and install myself. I installed the head unit without any problems. But just starting to investigate the installation of the amp or sub. Also can I use the existing speaker wire if I install an amp. I'm assuming that I can use it if I just replace the oem equipment with new speakers. Although I have not taken the dash and doors apart yet to see how they have wired.
Posted By: dwarren
Date Posted: June 23, 2005 at 2:00 PM
Sounds like a re-wire is in order by the way you are describing it. You say there are only two sets of speaker wires in the dash? A + -, and another + -, one for front and one for the rear? Take a nine volt battery and pop the speakers to see what is what. You may have a factory amp.
Of course you would benefit from using an amp aside from deck power, but you don't have to. (I strongly recommend an amp though, buying a good set of comps then cheating them with lousy power is nonsensical).
Do this in phases if necessary, do your interior speakers with an amp then do a sub upgrade later.
Posted By: Jmeese
Date Posted: June 23, 2005 at 2:27 PM
I will pull the deck out and verify but I only remember a front and rear both had two wires +,-. What do I do with the two speakers in the rear doors?
Posted By: Jmeese
Date Posted: June 23, 2005 at 9:18 PM
Ok I did verify. I have four speaker hook ups (2 wires each + and -) front left, front right, rear left, rear right. So if I have 6 speakers working from this output from the deck then obviously I must have two speakers running off of each of the front. so I will hook the componets to the fronts but what do you recommend for the back? Replace with a different speaker or leave as is? If replace what type of speaker? Can I put two 6 1/2 subs in the doors if I'm adding an amp?
Posted By: dwarren
Date Posted: June 23, 2005 at 9:27 PM
Yes there is probably a x-over in line of the mid and tweeter in the car, but that will be replaced if you upgrade to another set components.
as far as the back speakers go, just fit a coaxial speaker that is the same size, keep it simple.
Posted By: Jmeese
Date Posted: June 23, 2005 at 9:43 PM
what do you think of cerwin vega and bostin acustics for component sets?
Posted By: dwarren
Date Posted: June 23, 2005 at 11:31 PM
how do they sound to YOU.
