Alpine amp troubleshooting
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=58275
Printed Date: February 06, 2026 at 6:33 AM
Topic: Alpine amp troubleshooting
Posted By: Sungura222
Subject: Alpine amp troubleshooting
Date Posted: June 23, 2005 at 5:25 PM
Hi, Ive got an alpine MRV-T707 amp running an alpine sub.
When I was playing the music, the amp suddenly shut down and does not work anymore. The green LED still comes on on ignition/remote turn on, and then it becomes dim and stays dim. The sub does not play.
All power & ground connections are fine.
I've opened the back cover, but cannot see any apparent damage such as burn marks around components.
What could be possibly wrong? Can I repair it myself, or will I have to give it in to an authorised service centre.
Any feedback is appreciated.
Many thanks
Sun.
Posted By: tcss
Date Posted: June 23, 2005 at 5:50 PM
What type of sub(s) are you running? What is the ohm rating?
Date Posted: June 24, 2005 at 3:58 AM
Hi,
Im running one alpine SWR - 1240 sub in bridged mode. the Ohm rating is 4 ohms
theres more than plent power from the amp.
I thinks its overheated, since the day it happened, it was extremely hot weather.
Do you think if I disconnect & reconnect the power supply, it may reset itself & start working? Sorry if it sounds silly, im assuming the thermal overload protection kicked in, and can only be reset by disconnecting the power supply.
Chess.
Posted By: skoldspuppy
Date Posted: June 24, 2005 at 8:55 AM
Humor me on this but check the amount of voltage comming from the Remote Turn on wire, make sure it read 12volts at all times and does not vary
The reason I say this is, my friends 301M Fosgate amp did the same and it turned out to be the Headunit's remote wire was falty, it would power up to only 4 volts, we switched it to the ACC wire and got a full 12 volts and the amp started working again
Now if you have already tried this, then im out of suggestions
Good Luck
--Skold
2004 Honda Civic Ex 4Dr
Kenwood DDX-7015/W Nav
4 Fosgate T152C
Hifonics Brutus BX1500D
RE XXX 12 in a 4 Cube Snail Shell
Date Posted: June 24, 2005 at 9:12 AM
thanks skold,
it makes sense, since the amp is still turning on.
I will check for 12volts on the remote turn on wire
Thanks for your advice
chess (;-)
Date Posted: June 24, 2005 at 9:27 AM
Make sure you do it when its under load, AKA still connected to the amp
We tested it from the connector at the headunit
Later
--Skold
4 Fosgate T152C
