amp turn on question
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=58329
Printed Date: February 05, 2026 at 6:53 AM
Topic: amp turn on question
Posted By: bluetruck
Subject: amp turn on question
Date Posted: June 24, 2005 at 10:29 PM
if attaching an aftermarket amp to a factory head unit (that ran a factory amp) in a 99 dodge dakota with stock infinity sound. what wire should be used as the amp turn on lead? the one marked ACC or  ANT  i assume this is accessory and antena (sp?) but i wasnt sure which one was correct because to my knowledge no dodge trucks came with power antenas. i dont have a multimeter so i cant just see which one is cold and gets hot when the truck is on. any help is appreciated. thanks
Posted By: geepherder
Date Posted: June 24, 2005 at 10:53 PM
The blue wire will power up the factory amp.
Posted By: specialblendj
Date Posted: June 25, 2005 at 7:44 PM
Use the ACC wire.  This is your accessory power.  If you use the antenna wire, you amp will only work when your listening to am/fm, not cd's.  It may have a power antenna wire because they use the same harness as dodge suv's and cars that have power antennas.
