how hot is too hot for an amplifier?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=58368
Printed Date: March 21, 2026 at 2:34 PM
Topic: how hot is too hot for an amplifier?
Posted By: tim828
Subject: how hot is too hot for an amplifier?
Date Posted: June 25, 2005 at 9:59 PM
i have a kickersx1250.1 amp on my subs.  it has the digital readout on it.  the other day i happened to look in the trunk at it and it said it was 126 degrees.  now im not sure if this is actually hot for an amp.  i dont have much experience.  but i dont wanna burn anything up.  also had one more ?.  if i put a toggle swith on my amps to turn them off.  when you have the amp off for the highs will they still play just not with much power??
hope sum1 can help.
Posted By: stevdart
Date Posted: June 25, 2005 at 11:29 PM
If you don't smell smoke it must be okay.  But if it is hot to the touch, as when you can't keep the palm of your hand on it for a minute, then it's time to set up a fan cooling system.
You can toggle the amp off with a switch on the remote wire, but when it's off there will be no music.  The line out from the deck will still be physically connected and as long as the RCA's are in place the deck will not produce power.  You can find what will happen by removing the turn-on wire at the amp.  If your aim is to shut off the amps to allow a cool-down cycle, then it IS time to set up a fan cooling system.
Posted By: tim828
Date Posted: June 25, 2005 at 11:35 PM
i was thinking that.  i am fixing to redo the trunk.  i think i will port through rear deck and bring in some cool air.  thanks for the help
