I've been doing my research and have decided to go with the Brahma for a good SQL setup. I plan on pushing the sub with a clean 500-600w RMS the amp I am still undecided on but im leaning twords either a JL Audio 500/1 or a Zapco Referance series. My question is what is a ideal sealed enclosure size for optimal sound quality in the brahma series? also does a 10 inch sub require less box size than the 12 inch offerings? is there much difference between the 10 and 12? thank's ahead
If you can get a Brahma...
I mean.. a 12 has more radiating area and usually play a bit lower than 10's... that is to say, louder and lower. If you're going with a single woofer setup, I couldn't imagine being satisfied with a single 10"...
If you really going to spend Brahma kinds of cash, download WinISD and model the woofers' with the T/S parameters and look at the woofers response, particularly below about 40 hz... u'll find the 10 drops off quicker than the 12.. and in terms of absolute volume, is about 2-3 dB quieter at the same power level.
You'd want to model the woofer before building a box anyway eh?
Yes, typically, a 10 requires about 1/4 - 1/3 cft less airspace than a 12" brethern.
Either amp would be outstanding choices.
WinISD-------------
I tried using WINISD and its confusing as all hell..i dont really understand all the technical mumbo jumbo.. also the brahma isnt listed in there.. or atleast the copy i downloaded..
For my personal uses, the Brahma 10 is enough for me. However it really is a purpose built sub, working well for people who need to use tiny enclosures. You get 40% more cone area with the 12, so it might be a better choice. We normally recommend around 1 cubic feet sealed for the Brahma 12.
Steven Kephart
Adire Audio
Steven.. are the new brahma's available for purchase yet? also can you give me a link to some authorized retailers.. thanks
I spend 20 minutes typing that and you call me a dick?
So my prose is a bit smarmy but I'm just trying to help!
Really didn't mean to offend.
Unfortunately they are not available yet. However they will be available very soon. And shortly after that we will have an updated dealers page that should help you.
Steven Kephart
Adire Audio
