MB Quart components any good?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=5948
Printed Date: May 08, 2024 at 9:11 AM
Topic: MB Quart components any good?
Posted By: KBToys
Subject: MB Quart components any good?
Date Posted: November 27, 2002 at 8:47 AM
I am going to replace my polks and was thinking of using MB Quart speakers. Here are the model's I was thinking of getting DSD-216 or RSC-216. I don't know much about MB Quart and was looking for feedback on these. I will be using a alpine amp pushing them at about 60watts. Are these any good? How do they sound? Also if you know of another brand that is cheap let me know.
Posted By: bberman1
Date Posted: November 27, 2002 at 10:32 AM
I would go with the RSC 216 over the DSD 216 Mb Quart is one of the top names when it comes to speakers. The mids highs on them are extremely loud clean and crisp. They do however lack when it comes to the low end bass. My suggestion to you is go to a local store that caries MB Quart and listen to them and then their competitors and see what sounds best to you. But MB Quart is defiantly worth the money.
Posted By: KBToys
Date Posted: November 27, 2002 at 10:51 AM
What is the difference between the two?
Posted By: bberman1
Date Posted: November 27, 2002 at 12:42 PM
https://www.mbquart.com/Mobile_detail.asp?model=DSC+216
Specs: DSC 216
Impedance: 4 Ohms
Frequency Response: 40-32k
Sensitivity: 85.5 dB
Power Range: 50-120 watts
Crossover Freq: 4200Hz Hz
Crossover Slope: 12 dB/octave
Notes:
Components:
PQM 13 HX Tweeter .5" (13mm) Discus Tweeter
DWC 160 Midrange 6.5" (160mm) Discus Midrange Driver
QX 120 Xover Crossover for Discus Series Systems
GRILLE: 13HX Grilles 0.5" (13mm) Tweeter Grille
MOUNT: 13HX FLUSH Rings Flush Mounting Ring for 13HX Tweeters
QM 2216.79 MS Mounting Kit Surface Rings & Grilles for 2216 and 160TX-2
https://www.mbquart.com/Mobile_detail.asp?model=RSC+216
Specs: RSC 216
Impedance: 4 Ohms
Sensitivity: 86 dB
Power Range: 60-130 watts
Crossover Freq: 3700Hz Hz
Notes:
Components:
RTC 19 (19 NX) Tweeter .75" (19mm) Reference Neo Tweeter
RWC 160 Midrange 6.5" (160mm) TX-3 Midrange Driver
GRILLE: 19NX Grilles 0.75" (19mm) NX Tweeter Grille
MOUNT: 19NX ANGLE Rings Angle Mounting Ring for 25NX Tweeters
MOUNT: 19NX FLUSH Rings Flush Mounting Ring for 19NX Tweeters
MOUNT: 19NX SURFACE Rings Surface Mounting Ring for 19NX Tweeters
QM 160.78 AUFBAU Mounting Kit Raised mounting ring (.47") for 160.03KX
QM 160.79 MS EINBAU Mounting Kit Flush Rings & Grilles for 160TX-3
Above you can compare the two as you can see they are completely different. They operate at different frequencies and use different components  If you have the extra money I would look @ the QM 218.61Q series they go for about 300 on eBay  But once again be sure to listen too all your options and choose the set you like best.
Posted By: RocknLesabre
Date Posted: November 28, 2002 at 7:04 AM
https://www.carreview.com/Speakers/PLS_1805_77crx.aspx
that is a link to some reviews on MB QUART speakers, different models and different specs...I found it interesting and helpful.
Posted By: amador
Date Posted: November 29, 2002 at 10:00 PM
I STRONGLY SUG. THAT YOU GO WITH MB QUARTS THE ARE THE BEST WHEN IT COMES TO MIDS/HIGHS AND IF YOU ARE SERIOUS ABOUT SOUND I SUGGEST YOU GO WITH THE RSC IT MIGHT COST A LITTLE MORE BUT WELL WORTH IT GOOD LUCK
sonic boom
Posted By: amador
sonic boom
Posted By: rharris19
Date Posted: December 03, 2002 at 11:56 AM
If you are willing to spend $230, i would go a step above the rsc and the the psd.  I bought mine on ebay for 230 shipped and the rsc's are only like $20 less, so i would just go with the psd-216's
